Anyone have a valve similar to this in your stash?
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sun Jan 25, 2026 10:31 pm
I'm gathering parts to build a '26 roadster fuel delivery truck with my grandsons. I know many of you have all kinds of interesting things hidden away. I'm looking for a valve similar to this that would be used on a fuel delivery truck. Anyone out there have something similar they would be willing to part with?
Re: Anyone have a valve similar to this in your stash?
Post by TRDxB2 » Sun Jan 25, 2026 11:59 pm
I'm gathering parts to build a '26 roadster fuel delivery truck with my grandsons. I know many of you have all kinds of interesting things hidden away. I'm looking for a valve similar to this that would be used on a fuel delivery truck. Anyone out there have something similar they would be willing to part with?1925_Ford_Model_T_Texaco_Tank_Truck-rvl.jpg
I'm sorry but I don't know what exactly our looking for. But did find this https://www.etsy.com/listing/1615131611 ... 0ee4a61427
Might be to modern
Then I found this & expect you mean the 3 https://www.schwankeengines.com/product ... pzJBvufOq1
Getting educated need to search on Fuel delivery elbow
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Mon Jan 26, 2026 8:44 am
Frank, I'm looking for the big brass valve at the bottom of the bulk tank. Your picture of the "Purol-Pep" truck is better than my pic. I only need one of the valves.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Jan 26, 2026 9:38 am
Try Dixon D 75 drum valve very similar
Post by DanTreace » Mon Jan 26, 2026 12:31 pm
Craig
Thanks for that lead, tried to google but didn't know the name. ULine has a 2" thread brass one, handle could be painted to hide modern look or modify it.
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Jan 29, 2026 1:22 am
Is this what you are looking for?
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Thu Jan 29, 2026 7:27 am
Thanks for the replies, even though the drum valves look similar, it looks like they all have an external "gate" to shut off the flow of the liquid, Nothing to attach a delivery hose to. From period photos the valves have a connection, such as a cam lock hose to deliver to a storage tank and also a hook to hold the 5 gallon fuel cans while filling
Ya, I know that's not a "T"...... just showing the fuel cans.
Post by TXGOAT2 » Thu Jan 29, 2026 11:01 am
I used to have 3 tank valves on a Texaco tank. When it dries out, I'll see if I can locate them.
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Thu Jan 29, 2026 11:23 am
When it dries out....... It's been getting down to 0 or below up here. Last I looked they were predicting -12 degrees for Saturday morning. I should be thankful it's only -12. Lots of places are far colder than that. Thanks for looking Frank.
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sat Jan 31, 2026 9:25 pm
Hey Pat, I hope you're drying out! Our -12 degree morning was a false alarm, it was only -1. Let me know if you happen to find your valves, I appreciate your help. My 2 Jr High grandsons have been wanting to do something with a 1926 running gear that I have, so I told them I would work on gathering parts while the weather is nasty (0 degree weather) and we could start when things warm up.
Post by TXGOAT2 » Sun Feb 01, 2026 11:11 am
It's supposed to get p to 60 F today, and most of the snow is gone and the slop dried up. I hope to get a chance to look around today or tomorrow.
Well, the valves are not on the tank, but I did establish that they are 1 1/2" NPT on the tank side.
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sun Feb 01, 2026 9:50 pm
Hmmm, My tank has a single 2" NPT (2.375 OD). I think that's somewhat standard. It'll be interesting what your valves are if they show up.
Post by TXGOAT2 » Sun Feb 01, 2026 10:10 pm
They're here... someplace, along with about 500,000 other assorted items. The tank has 3 compartments, small, medium and large. I believe the smallest compartment was for motor oil, the medium sized one for kerosene, and the large one for gasoline.
Post by TRDxB2 » Mon Feb 02, 2026 1:19 pm
Sent 2 PM's of possible sources one you will buy
fiel elbpws b.png (205.24 KiB) Viewed 848 times
