Rear End Install
lmazoway
Last Name: Mazoway
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T
Rear End Install
Post by lmazoway » Fri Mar 27, 2026 3:00 pm
I removed the differential which was pretty straight forward. I'm ready to reinstall the unit and am wondering if there is something I should be aware of so I don't mess it up. I'm going to grease the universal joint heavily before installing.
Thanks for the help.
Larry
Kennebunk, Maine
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Rear End Install
Post by Rich P. Bingham » Fri Mar 27, 2026 3:18 pm
If you pack the ball with stiff grease around the U-joint it’s easier to align with the trans. tail shaft, but it’s still best to have help as you move the axle/driveshaft assembly into position.
Get a horse !
Post by TRDxB2 » Fri Mar 27, 2026 4:18 pm
As stated above you'll need help because the end of the u-joint has a mind of its own when aligning with the transmission ball cap fourth main. While not necessary they do make a tool to support.. DIY? .
ujoint tool.png (39.5 KiB) Viewed 66 times
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Mar 27, 2026 6:08 pm
Read these threads in order to avoid pinching or cutting your fingers on the driveshaft ball while installing universal joint shaft into the "fourth main" of the engine.
https://www.mtfca.com/discus/messages/1 ... 1300480114
https://www.mtfca.com/discus/messages/1 ... 1292108551
Since my contribution to the 2011 thread, I have acquired universal joint alignment Z tool at a swap meet, which is basically a thin, open end wrench with a long handle (Dan Hatch posted a photo of one in the second link I posted above).
Post by Allan » Fri Mar 27, 2026 6:10 pm
Make sure the square head on the spring centre bolt is located in the square hole in the rear cross member on the frame, if indeed you took the spring out with the rear end.
Alan from down under.
