Rear End Install
lmazoway
Last Name: Mazoway
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T
Rear End Install
Post by lmazoway » Fri Mar 27, 2026 3:00 pm
I removed the differential which was pretty straight forward. I'm ready to reinstall the unit and am wondering if there is something I should be aware of so I don't mess it up. I'm going to grease the universal joint heavily before installing.
Thanks for the help.
Larry
Kennebunk, Maine
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Rear End Install
Post by Rich P. Bingham » Fri Mar 27, 2026 3:18 pm
If you pack the ball with stiff grease around the U-joint it’s easier to align with the trans. tail shaft, but it’s still best to have help as you move the axle/driveshaft assembly into position.
Get a horse !
Post by TRDxB2 » Fri Mar 27, 2026 4:18 pm
As stated above you'll need help because the end of the u-joint has a mind of its own when aligning with the transmission ball cap. While not necessary they do make a tool to support.. DIY? .
ujoint tool.png (39.5 KiB) Viewed 25 times
