New Leaf Springs Question
rmdpchester
Topic author - Posts: 9
- First Name: Raymond
- Last Name: Chester
Question: Is there any difference in quality of leaf springs from Mac's, Snyder's, or Lang's? The prices are quite a bit different. '27 Touring.
Front 8-leaf
Langs 3800CL8:v $225 unclear if clips/bushings included
Snyders T-3801-B7: $250 with clips/bushings
Macs T-3800-B: $420 no clamps/bushings
Rear 9-leaf
Langs 3824CL9: $447 unclear if clips/bushings included
Snyders T-3824-B8: $435 no clamps/bushings
Macs 3824: $520 no clamps/bushings
My springs look to be original...very pitted and passengers in the back seat bottom out on any bump, so I plan to replace them with fresh springs, bushings, etc. A response to my Facebook post on the same question yielded yet another vendor, http://t-springs.com/. Which springs to buy? Decisions, decisions.
Front 8-leaf
Rear 9-leaf
Mike Royster
- First Name: Michael
- Last Name: Royster
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
Re: New Leaf Springs Question
Raymond:
If you end up buying new springs I would like one of your rear leaf springs, just one. I am rebuilding the rear end on my 1916 Runabout and found the 3rd spring from the bottom is broken through the center bolt. I'd be happy to purchase one.
Thanks,
Mike
Thanks,
Mike
rmdpchester
Mike, Certainly! It'll be a little while though. I have to save some pennies.
We have buying our Model A springs from Travis. They come to use with brass bushings installed.
- Last Name: House
Mike,....Front and rear springs from the last 2 Model T years are entirely different from the brass era. They’re arched differently and the ends aren’t tapered. Some expert will correct me if I’m wrong..... they always do..
Mike Royster
George, good catch. I did not even notice his was a 27!
Anybody got a 16 spring they don't need? Or know where I can get one?
Thanks,
Mike
Thanks,
Mike
Joss
- First Name: Joss
- Last Name: Sanderson
Pretty sure the difference is that the supplier is selling to Snyder's and Langs directly. Mac's then buying from them. Same spring.
A thought is to have a local person roll a new base leaf. They will use slightly thicker stock. Better support especially for the front. I did this years and thousands of miles ago. Still happy.
