Youngblood combination carburetor and choke adjustment rod aftermarket
Shemp
First Name: Randy
Last Name: Reysen
* REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Post by Shemp » Sat Aug 24, 2019 11:39 pm
I came across this last night at a good friend's shop because I was in need of a knob for my choke rod. Only a small bit of the box and instructions remain, but what does, appears to be a cool 2 in 1way to adjust your fuel and choke your engine for startup. It was made by the Youngblood Sales and Manufacturing Company Atwood, Kansas. Anybody have one laying around with the intact instructions? Did anyone ever use one? Thanks for your insight.
Re: Youngblood combination carburetor and choke adjustment rod aftermarket
Post by Allan » Sun Aug 25, 2019 4:53 am
Here in Australia I have seen and found a similar set-up. This allows the mixture control rod to be longer and mounted within easy reach on the steering column. The universal type joint halves are nickel plated brass castings on ours.
Dan B
Last Name: Blaydon
Post by Dan B » Tue Aug 27, 2019 8:31 pm
Here’s the instructions. I saved the pictures from an eBay auction a couple months ago.
Dan B
Last Name: Blaydon
Post by Dan B » Tue Aug 27, 2019 8:32 pm
Instructions
Shemp
First Name: Randy
Last Name: Reysen
Post by Shemp » Tue Aug 27, 2019 8:33 pm
You are amazing!!! Thanks! Super helpful though thanks again!
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Tue Aug 27, 2019 9:45 pm
That is a very handy device. I had a similar one on my dashboard when I ran a straight through NH.
Shemp
First Name: Randy
Last Name: Reysen
Post by Shemp » Sat Aug 31, 2019 5:22 pm
Thanks again to Dan B for the photos of the diagram and instructions he saved I installed the combination choker and adjuster today and it works great!
Dan B
Last Name: Blaydon
Post by Dan B » Sat Aug 31, 2019 9:00 pm
It looks great! Not all neat T accessories are as functional.
Glad I could help.
