Ruckstell oil
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
Ruckstell oil
Post by Divcoone » Mon Sep 23, 2019 8:08 pm
What oil/grease is recommended for a Ruckstell?
Last Name: Strange
Re: Ruckstell oil
Post by CudaMan » Mon Sep 23, 2019 8:43 pm
Last Name: Tannehill
Board Member Since: 2002
Re: Ruckstell oil
Post by JTT3 » Mon Sep 23, 2019 8:48 pm
I like the 80W-90 Lucus gear oil. I like it because of its climbing ability. In my Ruckstell I added the tab that, I think, Dan McEachern talked about to direct more lubricant in the inner section of the Ruckstell
Susanne
First Name: Susanne
Last Name: Rohner
Re: Ruckstell oil
Post by Susanne » Tue Sep 24, 2019 12:42 am
Curse me if you must, but I switched from 85-140 back to 600W in mine, and the problems I had (hard shiftinng, whine, etc._ went away. I only have about 4-5000 miles on the car since the switch, so I worry about it's imminent failure... (Yes, I know it's "steam oil")
Sorry. I know people thing modern oil or nada, but it works for mine. Not conjecture, but what I have run in it for miles. YMMV. With all the bronze in the rear end, I feel safer knowing my rear end oil is no longer attacking it.
Re: Ruckstell oil
Post by Original Smith » Tue Sep 24, 2019 10:03 am
I'm been running Sta Lube SAE 140 for years in all of my Ruckstells.
StanHowe
First Name: Stan
Last Name: Howe
Re: Ruckstell oil
Post by StanHowe » Tue Sep 24, 2019 10:45 am
I've torn ruckstells down that have been running modern GL 5 for years. The only discernable thing I have seen is a greenish tint to the bronze plate.
Any modern lube - cheapest possible crap from tractor supply - is so far superior to the best there was 100 years ago that there is no comparison.
Personally, I like Lucas 80-140 gear lube but I don't think it makes much difference overall as long as you don't run heavy grease that won't work its way in between the bronze plate and the thrust plate.
Re: Ruckstell oil
Post by Norman Kling » Tue Sep 24, 2019 11:03 am
You need a lighter grade oil than 600W for this reason: There are small holes inside the carrier which allows oil into the planetary gears and differential gears. For this reason you should also direct oil into these areas upon assembly of the axle. Also put some in the area where the shifter is bolted. 80W140 or 90 works very well.
lesvonnordheim
First Name: Les
Last Name: Von Nordheim
Re: Ruckstell oil
Post by lesvonnordheim » Wed Sep 25, 2019 1:04 am
I have been using 90-140 synthetic gear oil from McMaster Carr. Been using it for over 20 yrs. and very happy with the results....it does not attack the Bronze thrust washer. The gear oil stay's clear and does not turn a Bronze color like I have found using conventional gear oil.
