Twin High Transmission accessory
Topic author - Posts: 162
- First Name: Douglas
- Last Name: Keppler
Has anyone ever seen one of these?
1924 Touring car
There's No Substitute for Proper Lubrication
- First Name: Joe
- Last Name: Bell
Re: Twin High Transmission accessory
Just saw one the other day, Constantine has one, neat looking piece and light weight.
- First Name: Les
- Last Name: Schubert
Nice piece. I’ve thought about doing something a bit similar with a Laycock overdrive.
I've never seem or heard of one in 55 years of' T'ing.
This forum is full of surprises.
- First Name: Constantine
- Last Name: Mandylas
Joe is correct. I have one that needs a rebuild. You could say it's a thinking man's Model T transmission (so Gary Norton in MI, it's certainly not for you monkey boy).
Here's some pics.
- Last Name: Williamson
- * REQUIRED* Type and Year of Model Ts owned: 1913
I would like to buy one. If anyone has one to sell, please let me know.
Richard Williamson
Richard Williamson
- First Name: Thomas
- Last Name: Butterworth
- * REQUIRED* Type and Year of Model Ts owned: 1911 speedster
I had one in my 13 speedster . Worked great but you can get it in neutral and it won't go back in until stopped . I did that on first ride put it in a ditch only hurting my pride .
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
I’ve got the TT version going in my truck. Just painted it two nights ago. I’d also like to find another for parts just to have lying around.
Brad
Brad
Jeepbone1 wrote: ↑Thu May 14, 2020 8:27 amI’ve got the TT version going in my truck. Just painted it two nights ago. I’d also like to find another for parts just to have lying around.
Brad
[/quote
That's not the TT version of the Twin-High, you have the "Twin-High Hi-Lo type" a completely different animal.
"Twin-High Hi-Lo type" was only made for TT and was rear mounted. The Twin-High came in both car and TT versions and was a light weight front mounted unit.
- First Name: Dennis
- Last Name: Prince
I have a TT with a Twin-High Hi Lo type and would like to know more about it, like are parts available for it? and those with any experience with one is it noisey and do they shift easily? I bought the truck because of it and haven't gotten it running. I have been keeping my eyes open for doors, if I can find 4 doors I want to build a crew cab.
Note that the Twin-High Hi Lo type tranny was also made for the worm drive AA.Dennis Prince wrote: ↑Tue May 19, 2020 9:43 pmI have a TT with a Twin-High Hi Lo type and would like to know more about it, like are parts available for it? and those with any experience with one is it noisey and do they shift easily? I bought the truck because of it and haven't gotten it running. I have been keeping my eyes open for doors, if I can find 4 doors I want to build a crew cab.
- First Name: Brad
I’ve seen two slightly versions of the one I have. Assuming yours is one of those, no parts are not available. If you’re good with a micrometer, you should be able to match up the bearings with new replacements. Mine were in nice shape and the races looked almost brand new. It was just all sludged up. if you plan to go through it, here’s what I did. Separating the unit from the torque tube and driveshaft is a Royal PITA. You just have to remove the u joint pin and u joint, take out the two clamping bolts from the front of the trans. Slide the torque tube off the drive shaft. There is then a pin holding the drive shaft to the input of the trans that took me a solid hour and a half to get that out alone. It’s smooth sailing from there. Six bolts are holding it to the rear axel like a normal torque tube. The shifters come out without much fuss. There ten 3/8” bolts holding the case together. Four are 1”, four are 4” and two are 4-1/2” all should have a 9/16” head. Now is where I suggest taking pictures and remembering orientation. One slider pulls out of the back no problem. Once it’s split into thirds, you can do the bulk of your cleaning with brake cleaner to knock most of the gunk off. Then the front has a 1-1/16 nut with a cotter pin. Once that’s removed, start taking pictures because it can get to be a whole lot real quick. Everything should slide apart from there. After that, throw it back together, make some gaskets, squirt some paint for effect and you’re golden. Time consuming but probably worth the peace of mind that it’s solid. Mine shifted pretty easy but I also only shifted it while turning the motor over by hand. Any noise would probably be attributed to bearing/gear wear. Like I said before, the guts in mine are pretty nice so I don’t expect much problem.Dennis Prince wrote: ↑Tue May 19, 2020 9:43 pmI have a TT with a Twin-High Hi Lo type and would like to know more about it, like are parts available for it? and those with any experience with one is it noisey and do they shift easily? I bought the truck because of it and haven't gotten it running. I have been keeping my eyes open for doors, if I can find 4 doors I want to build a crew cab.
- Last Name: Prince
Thanks Constintine and Brad, this project is still a ways down the list but glad to know more about it. Dennis
- First Name: William
- Last Name: May
That's a really impressive accessory! Looks like it was well engineered!
I want one if anyone has one to sell.
Richard
Richard
