Cool-A-Ford valve cover accessory information?
Topic author - Posts: 147
- First Name: Alex
- Last Name: Dragone
- * REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
I have this interesting aluminum accessory valve cover for a Model T and would like to know more about it. Obviously the front is a screen to catch air to cool the valves? But the hole on the other end is puzzling to me. Its a round hole and has a hole at the top for a set screw. Does anyone have an idea of what is supposed to go there? More info on this accessory is much appreciated. Thanks!
Re: Cool-A-Ford valve cover accessory information?
Probably safe bet it is missing its "exhaust" pipe for the now-heated air theoreticaly removed from the engine...
No doubt, some people and their money were separated by this thing.
NH Full Flow Float Valves
- Last Name: Rodell
- MTFCA Number: 14035
- MTFCI Number: 13594
Flexible pipe to carburetor intake?
- First Name: Bill
- Last Name: Coyle
- MTFCI Number: 24067
I was thinking that also, pulling the air through by means engine vacuum... carb intake. What does the back side look like? It could introduce a lot of dirt into the valve area, but keep it out of the cylinders... Like an oil bath air cleaner.
Bill
Bill
- First Name: Bill
- Last Name: Hoffer
- MTFCA Number: 32571
- MTFCI Number: 24364
Early automotive age positive crankcase ventilator. Genius at work - way ahead of its time.
Cheers, Bill
Cheers, Bill
- First Name: Jeff
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
- MTFCA Number: 25636
Most likely some sort of a road draft tube that hung below the engine in the stream of air under the vehicle to create a slight vacuum and keep the crankcase fumes out of the car.
