need info on plate under radiator that anchors tension rods, size and shape.
this is for 1926 mailman special
send private message for photos
snowbird parts info
- Last Name: Rodell
- MTFCA Number: 14035
- MTFCI Number: 13594
Re: snowbird parts info
William,
Here is a drawing showing the parts of the Snowbird. The plate you are referring to is trapezoidal and replaces the bar under the front spring clamp. It should be easy to have one laser cut from 1/2" steel. I would love to see pictures of your Model T snow machine.
Jim
Jim
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
- MTFCA Number: 2406
- MTFCI Number: 22213
If you "click" on the drawing it will enlarge. Do it twice to enlarge twice.
1922 Coupe , 1926 Touring
Topic author - Posts: 7
- First Name: William
- Last Name: Crogan
- * REQUIRED* Type and Year of Model Ts owned: 25 TT, 25 touring, 27 pickup,13 runabout
- MTFCA Number: 8596
would like to see just what this front plate looks like for a better copy, any idea where there might be one to look at?
- First Name: Kevin
- Last Name: Bruso
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
- MTFCI Number: 20203
I sent you an email regarding this part....
