What have you done to your Model T in February?
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sat Feb 01, 2020 1:04 am
I opened the garage door so it could get some fresh air.
Bill Anziani
First Name: Bill
Last Name: Anziani
Re: What have you done to your Model T in February?
Post by Bill Anziani » Sat Feb 01, 2020 8:43 am
Finishing up on installing new transmission drums, and installing a skat crank
Graybeard77
First Name: Clyde
Last Name: Gibson
* REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan, 1926 Roadster
MTFCA Number: 32266
Post by Graybeard77 » Sat Feb 01, 2020 10:12 am
Going to get the T out of the trailer and get it ready for Florida. My outdoor shop is going to be in the 40’s today. Have a great day, Clyde
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Sat Feb 01, 2020 11:57 am
Today’s project.
New nuts for the starter ;)
Jeff Perkins
Last Name: Perkins
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout 1926 Touring
MTFCA Number: 10642
MTFCI Number: 17799
Post by Jeff Perkins » Sat Feb 01, 2020 8:56 pm
Finished up my total rebuild of the front suspension, all bushings replaced and new spindles. Also included disassembly of the spring and painting it with slip-kote. Took the car out for a spin (26deg.F.) and it drove very nice. I really noticed the difference.
1913 Model T Runabout,
1926 Model T Touring,
1948 Chrysler New Yorker,
1991 Mazda Miata
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sat Feb 01, 2020 11:39 pm
Today, I assembled the rear axle for my 26 coupe.
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
MTFCA Number: 30527
MTFCI Number: 23207
Post by richc » Sun Feb 02, 2020 6:17 pm
February 2nd and it’s sunny and 76 degrees in Tulsa! Seemed like an opportune time for the inaugural test drive of my 1924 TT chassis. I had started the engine half a dozen times or so letting it run 20 or 30 minutes over the past several weeks - even got it to start hand cranking it off the magneto! All I needed to do was dial in the toe-in and connect the drag link. Sooo, off I went for a couple of laps around The Model T Garage storage property.
The truck will eventually have a C-Cab body and an express pickup bed. It also has a TT KC Warford auxiliary transmission and a Prus head. For this first drive I left the Warford in underdrive and found the chassis quite peppy when I eased the Ford transmission into high pedal. You can see from the photo I’ll need to install the battery hold down clamps. I’ll also need to adjust the clutch as the clevis went over top dead center as I was driving back into the garage! Got it stopped in time, however.
Rich C.
jachady
Last Name: Chady
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
Post by jachady » Sun Feb 02, 2020 11:01 pm
Buttoned everything back up so I can run her to a friends funeral this weekend.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sun Feb 02, 2020 11:07 pm
Today, I put the rebuilt rear axle back under my 26 coupe.
Bryce
First Name: Bryce
Last Name: Putnam
* REQUIRED* Type and Year of Model Ts owned: 1925 C cab 1923 Fordor 1923 Touring 1919 Centerdoor 1915 Speedster
Post by Bryce » Mon Feb 03, 2020 10:45 am
I stopped for gas
AndreFordT
First Name: Andre
Last Name: Valkenaers
MTFCA Number: 23792
MTFCI Number: 19330
Post by AndreFordT » Mon Feb 03, 2020 1:16 pm
Working since New year on the total rebuild of a 1914 rear axle. Installed also disk brakes on it.
On tuesday the axle will go back under the car.
Andre
Belgium
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
MTFCA Number: 50306
Post by modernbeat » Mon Feb 03, 2020 1:42 pm
Built up a pair of McEachern safety hubs in preparation for the disc brake conversion on our mountain camping car.
Jason McDaniel
Jwinters
First Name: Joseph
Last Name: Winters
* REQUIRED* Type and Year of Model Ts owned: 1923 pickup
MTFCA Number: 49892
MTFCI Number: 24731
Post by Jwinters » Mon Feb 03, 2020 5:41 pm
I sent the motor out for a rebuild
I am installing new tires and painting the wheels
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
MTFCA Number: 15143
Post by Plankhill » Tue Feb 04, 2020 7:22 am
Started putting the Speedster back together. Rebuilt engine and Ruckstell with 3:1 gears.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Tue Feb 04, 2020 1:21 pm
I started work on a hood blanket to go with the winter front I made last month. Dan Killecut was kind enough to send me some pictures of his to use as inspiration. I taped up and cut out some sheets of newspaper to make a pattern, then used the pattern to cut some black woven blanket material from Walmart to fit over the hood top and sides. Next I cut the black vinyl outer covering to match the blanket material, plus 3/4 inch seam allowance all around.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Wed Feb 05, 2020 1:51 pm
I finished the fabrication of the hood blanket for Betsy today, here are some pics:
critterpainter
First Name: Bill
Last Name: Dodd
* REQUIRED* Type and Year of Model Ts owned: 14 T Touring
MTFCA Number: 27186
Post by critterpainter » Wed Feb 05, 2020 8:56 pm
Started putting my rebuilt engine back in my 14 and putting it together. While it was out someone decided to help me and placed many of the nuts and bolts in a can. The rest just flew the coop. Hopefully I will be done by Friday in spite of cold weather.
14 Touring
critterpainter
First Name: Bill
Last Name: Dodd
MTFCA Number: 27186
Post by critterpainter » Sat Feb 08, 2020 8:20 pm
Ok so I missed by one day. With lots of help from friends, the radiator got installed today, along with 5 gallons of fresh gas. It was too tight for we to crank start, but it was close. Coasted it 20' and and it was running. After the first start, I could light it off with a pull of the crank. A very good day indeed.
14 Touring
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sat Feb 08, 2020 11:52 pm
Today, I finished up the rear axle install on my 26 coupe and drove it for the first time in 3 years!!
MTFCA Number: 52564
Post by Mark Gregush » Sun Feb 09, 2020 1:33 am
RE-installed the intake/exhaust manifolds and timer on the 25. The exhaust manifold was off after I borrowed it for the the 21 when I took the Chevrolet over head off. Need to install a coil box, exhaust pipe & muffler then barrow the battery and coils out of the 21, add gas and water and see if it still runs. Still need to get wheels sorted out. It's a bugger when you have to share parts between two cars! :lol:
1920 Dodge touring
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sun Feb 09, 2020 2:16 am
In a couple weeks it might get up to 40, so I will have to go for a run. Roads are dry right now and not much salt on them. 4-6 inches of white stuff coming tomorrow.
NealW
First Name: Neal
Last Name: Willford
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1915 Runabout
MTFCA Number: 50256
Post by NealW » Sun Feb 09, 2020 2:56 pm
I'm currently at a stopping point on my 15 runabout restoration until I get my engine and rear axle back, so now was a good time to rebuild my spare coils. In the fall of 2018, our 21 touring had a coil go bad. At the time Erik Larson had a rebuilt set of coils for sale that wasn't too much more than just getting my coils rebuilt, so I bought them and put the other aside. Erik uses the ECCT to tune the coils, and could tell the the 21 ran better than it did even before one of the coils died.
Well, this year my in-laws were very generous at Christmas so I decided to get an ECCT tuner to keep my current coils in shape and try to get at least one of the removed coils in top shape as a spare. My spare coils consisted of one old Ford and three 1961 era KW's, and initial testing showed that the Ford capacitor was dead, and the other three had low readings. The MTFCA electrical booklet and the modelt-tips.com videos on coil rebuilding were helpful. What wasn't totally clear to me at the time was how different internally the Ford and KW's were. The Ford coils seem more robust and a little easier to solder the new capacitor in than for the KW's. I realized the hard way that the KW capacitor wires aren't in quite the same location as the Ford's, and accidentally broke the fine KW wires coming from the secondary winding area of the coil. Fortunately I was able to get them repaired. Later I found a posting showing a CAT scan of a KW and where the wires and capacitor were internally. I wish I'd found that earlier!
After replacing the capacitors I checked their capacitance readings, along with checking the resistance between the side poles on the box. Fortunately I did that before re-tarring, as one of the capacitors needed re-soldering to get a correct reading. I re-melted the chipped out tar and sealed up the insides. I decided not to test my lovely wife's patience and didn't use the stove top, but instead used a propane torch and a portion of a can to melt the tar. I think next time I'd use an old serving spoon to hold the tar chips while heating.
I found that the ECCT tuner was pretty easy to use and to get all four in good running condition. One defied tuning, so I replaced the points and it easily came back into specs.
For me, I probably get as much enjoyment out of restoring, maintaining and learning how to maintain T's as I do driving them, so learning how to rebuild the coils was fun. For what it's worth, we are getting a bargain from the various people who service coils for hire. They do a lot for the price!
Neal
Wayfarer
First Name: Cory
Last Name: Woerth
* REQUIRED* Type and Year of Model Ts owned: 26 engine on a stand, Canadian '23 center door
Post by Wayfarer » Mon Feb 10, 2020 12:19 am
I bought my first one Friday !
Canadian ‘23 center door
Spent the rest of the weekend fussing over her, and taking little drives up and down the street to learn how to drive her.
Researching adjustments and then performing them, is next
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Mon Feb 10, 2020 7:42 am
Congrats Cory!
Now post a pic of your find.
Vern (Vieux Carre)
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
MTFCA Number: 31822
Post by Jim_PTC_GA » Mon Feb 10, 2020 9:39 am
I'm still working on my T body. This is taking allot of time seeing how everything has to be custom made, tweaked, and adjusted to fit. I was hoping to be done by now but it's looking like it will be summer before it's done.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Mon Feb 10, 2020 9:52 am
My '26 Coupe's pre-made brown carpet got a hole under my left heel.
I found carpet of a much better colour and had it edged by an upholsterer after I cut it to shape.
Floor, side panels and seat plinth.
JEC
Last Name: Cox
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
Post by JEC » Mon Feb 10, 2020 12:41 pm
Replaced the third rotten tire on my 15.
One more to go. Put the first coat of sealer on the last wheel.
JEC
Last Name: Cox
Post by JEC » Mon Feb 10, 2020 12:43 pm
First coat
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Mon Feb 10, 2020 1:29 pm
Neal
Yes we do. I've purchased a total of 6 outright from one of the coil rebuilders and have been very happy with them. I think I'll purchase two more then start learning to do the maintenance on them myself. That way I can always keep a couple fresh spares in the toolbox and have two that are being worked on.
I bought an ECCT for this reason. Time to start using it more than I am.
1924 Touring
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Mon Feb 10, 2020 1:31 pm
That's nice work Mark. The T looks really snug in its custom coat.
1924 Touring
Post by Scott_Conger » Mon Feb 10, 2020 2:03 pm
Cory
congratulations on your purchase and welcome!
I'd advise you to make haste slowly on those adjustments. Most things on a T are obvious to a mechanically inclinded person, but some are not. Find a mentor in the area and bounce your ideas off of them for awhile and in the meantime buy T-1 book from any supplier. That is pretty much the T bible for working on these things. After that purchase and use, you'll find specific jobs which may require more information or detail, and there are dedicated manuals for most of those things, too.
NH Full Flow Float Valves
kelly mt
Last Name: Kelly
Post by kelly mt » Tue Feb 11, 2020 3:37 pm
Fired up the old 25 TT and hauled some salt blocks in to the sheep.
DanDy
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 17 roster, 17 touring, 22 coupe, 22 touring, 22 roadster pu, 24 TT cab
MTFCA Number: 9995
MTFCI Number: 18113
Post by DanDy » Tue Feb 11, 2020 4:00 pm
I averted a disaster!/
After jacking up 6"
After jacking up 6"
Truss failed
Truss failed
Post by Scott_Conger » Tue Feb 11, 2020 4:05 pm
Snow load?
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Feb 11, 2020 4:14 pm
Too many T parts hanging, maybe ???
Mounted new Firestones on my new Pharis Buffalo wire wheels for the '19 Centerdoor !!!
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Tue Feb 11, 2020 5:00 pm
Polished seal aerie on axles. Ready for Ruckstl to be reassembled.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Tue Feb 11, 2020 7:39 pm
Good idea to polish the seal section of the axles, Dean.
I wonder if there is such a thing as an inexpensive crack inspection kit (florescent penetrant) to check used axles for cracks before installation.
jachady
Last Name: Chady
Post by jachady » Tue Feb 11, 2020 8:42 pm
Fixed this! And put new head bolts in.
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Thu Feb 13, 2020 7:47 am
I’m replacing rear shackles and bushings. This isn’t a good sign. The only spare perches in my stash aren’t for improved cars. I put new bushings in and they seem to be ok but I’ll be on the lookout for better perches in the future.
modernbeat
First Name: Jason
Last Name: McDaniel
MTFCA Number: 50306
Post by modernbeat » Thu Feb 13, 2020 8:05 am
While the mule engine rebuild is stalled waiting on custom pistons, we've been working on the chassis.
Took apart the front springs and found serious wear in the front springs. The leaf springs will be replaced with a reproduction. The pivot point in the Hassler frame has worn, so it will be drilled out and bushed. Bronze bushings are going in all the other pivot points. The tie rod will get new bolts and bushings, but the spindle is surprisingly tight. Took off the speedometer parts and will replace the stand with a new nut.
Rebuilding a set of late hubs to convert to wire wheels. New bearings and seals, clean up the threads. New dust caps.
Stuck the refreshed wire wheels and tires on the car.
Jason McDaniel
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Thu Feb 13, 2020 9:03 am
Looking good Jason.
1924 Touring
dykker5502
First Name: Michael
Last Name: Deichmann
MTFCA Number: 29116
Post by dykker5502 » Mon Feb 17, 2020 6:40 am
Riveted the driveshaft to the brakedrum for my 1921 Pick-up (with 1926/27 gear) and made it run square.
Heating the rivets.
Hammering the rivet....
Checking for trueness - we used a "clock" to measure - then the drum was slightly turned and grinded to remove a little grove.
Then the heads of the rivets were turned down to a smooth surface
Ford Model T 1914 Touring
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Mon Feb 17, 2020 3:40 pm
Located a decent front fender, knocked out a couple of dents and installed it in 20 degree weather. A warm spell.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Mon Feb 17, 2020 8:19 pm
A little closer. Timer,wish bone,radiator,light bar coils, picked up grease for the U jôint.
Progress
Progress
abcarswell
First Name: Bruce
Last Name: Carswell
* REQUIRED* Type and Year of Model Ts owned: 1924 Model TT
Post by abcarswell » Mon Feb 17, 2020 10:11 pm
On the home stretch of the cosmetic portion of the restoration.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Tue Feb 18, 2020 11:39 am
Drying new paint
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Wed Feb 19, 2020 3:11 pm
Hubs cleaned & painted in the drying boooth ;)
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Thu Feb 20, 2020 8:57 pm
Installed wire wheels
Ok the hoist is handy
MTFCA Number: 52564
Post by Mark Gregush » Fri Feb 21, 2020 12:18 am
Dean that is looking like my house! :lol:
1920 Dodge touring
dunoon
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by dunoon » Fri Feb 21, 2020 2:26 pm
Got it back from the shop getting new interior, upholstery, roof and visor. A fantastic job.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Fri Feb 21, 2020 3:33 pm
Pictures? :)
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri Feb 21, 2020 6:58 pm
Still have the Ruckstell out of mine, but I did push the starter button the other day...
She spun right over. ;)
Dan B
Last Name: Blaydon
Post by Dan B » Sun Feb 23, 2020 8:29 am
Seems like it’s Ruckstell rebuild month!
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Sun Feb 23, 2020 8:22 pm
Test drive & top on
Test drive
Test drive
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sun Feb 23, 2020 9:16 pm
Shop looks great Dean. Liking the camper, too.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sun Feb 23, 2020 9:34 pm
Today, I pulled the radiator out of my 26 Coupe to replace the wood blocks underneath of the hood shelfs and the hood latches. In order to prevent the hood from coming unlatched.
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Mon Feb 24, 2020 2:04 pm
I’m on the reassembly side of rebuilding my rear end and torque tube. This logo is engraved on the end of my new axles. I’m not thrilled with that and was concerned that this would cause premature wear on the fiber spacer. I spent some quality time with a buffing wheel to smooth out the surface.
I need to thin down two fiber washers to fit my differential. Sanding, measuring. Sanding, measuring etc. I had to stop sanding after about an hour because I was running out of fingernails. My washers are down to about .049” each and I’m still not done yet. I’ll let my fingernails grow a few days before continuing. Those are tough washers. Maybe I should not have been worried about the abrasive logos after all.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Mon Feb 24, 2020 7:52 pm
Side curtain done one to go.
Side curtain
Side curtain
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Mon Feb 24, 2020 10:11 pm
Dean
I was hoping to do the same type of side curtain for my touring. Can you tell us what thickness of material you used and where you purchased it? Thank you.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Tue Feb 25, 2020 4:18 pm
David I use fabric from the local sewing center. Works for me . Second side done ;)
Angmar
Last Name: Bailey
MTFCA Number: 50335
Post by Angmar » Tue Feb 25, 2020 6:04 pm
Dave, that curtain is alright! Maybe show us how you did that and what materials were used.
Still crankin old iron
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Tue Feb 25, 2020 9:37 pm
Dean,
It comes in about 12 different gauges. Do you know which one you used? The piping is all the same.
Looks great by the way.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Tue Feb 25, 2020 10:42 pm
I do not know . It is .017 thick.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Tue Feb 25, 2020 10:46 pm
Started on the rear fenders ;)
Last Name: House
MTFCA Number: 115
Post by George House » Wed Feb 26, 2020 7:17 am
After selling my C Cab 2 years ago, I restored another one. Yesterday I changed the oil and greased/oiled everywhere in preparation for 2 parades - the 175th anniversary of New Braunfels and the Battle of Flowers in San Antonio. While under the truck I was surprised to see there’s no “belly strap” on this T. I think I have one restored and hanging up in the Conservatory. Today’s project
I don’t know why I turned out this way. My parents were decent people.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Feb 26, 2020 9:36 am
I replaced my leaking head gasket with a new one. I hope I used enough copper coat.
With the engine out of the car I'd just pick up the head and set it on. But with it in the car, I decided to go easy on my back.
A pair of studs will line up the head as it goes on.
Down she goes.
Ratcheting down the bolts before applying the torque wrench.
Why is the first picture repeated sideways at the bottom? I have no clue. I can't get rid of it.
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Wed Feb 26, 2020 12:57 pm
Steve, can you share the details of your head lifting hooks? I have an "L" shaped lifter from my uncle's stash that uses the lower portion of a two-piece sparkplug to thread into a hole. Did you do something similar or did you use pipe nipples?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Feb 26, 2020 3:01 pm
Here you go, Mark.
A pair of half inch pipe plugs drilled for 5/16" hooks. Put them in with a 5/8" wrench, turn the hooks toward the center of the head, and lock the nuts to keep them turned that way.
Last Name: House
MTFCA Number: 115
Post by George House » Wed Feb 26, 2020 4:37 pm
...or just use the bottom part of a 1/2” pipe thread spark plugs. Go to most hardware stores and buy 2 threaded eye hooks. I use just 1 unit to pull an entire engine but 2 will keep the head level.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Thu Feb 27, 2020 11:15 pm
Built fold out framework
45BF-AEC3-5C8C22A962A4.jpeg[/attachment]
dunoon
Last Name: Davis
Post by dunoon » Fri Feb 28, 2020 3:58 pm
Trying to put the car back together again. My body and all the fenders, running boards act have been restored and painted disassembled. I'm having a devil o a time getting everything to align enough to get it back together. Yesterday I got the rear fender on and tried to get the running board on couldn't do it, so attached the fender to the splash shield and payed the running board to get the holes in the fender to match up, then I looked the fender buckled about an inch on the edge about an inch. After I get everything on if I can my neighbor (the guy that restored the body and fenders will come and see what he can do to get everything back. He's a excellent body man he a top know restorer of MOPAR Mucle Cars know worldwide. He has shipped cars to Europe, S. Aferica and Australa. He know what he's doing.
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Fri Feb 28, 2020 5:30 pm
Put a top and headliner in this one.
NealW
First Name: Neal
Last Name: Willford
MTFCA Number: 50256
Post by NealW » Sat Feb 29, 2020 8:01 pm
Picked up my rebuilt engine and rear axle from Mike Bender today. Also fitted the new rubber floor mat, finishing off the body restoration. Spring has arrived in Kansas, so time to start putting all the restored pieces together of my 15 runabout back together!
floor mat.jpg (62.31 KiB) Viewed 18518 times
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Sat Feb 29, 2020 8:11 pm
I replaced the wood blocks under the hood shelfs, the hood latches and installed the new Brassworks radiator in my 26 coupe.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Feb 29, 2020 8:14 pm
One step closer to getting my Ruckstell together.
Went to Kevin’s shop today and picked up a pinion spool assembly. And the weather is hopefully getting warmer.
A couple shots of the Prus establishment, not much he’s not able to do here ! :)
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Mar 01, 2020 11:00 am
On the last day of the month I pulled the head and manifolds, preparing to improve the valves and (I hope) cure my low compression.
Wayfarer
First Name: Cory
Last Name: Woerth
Post by Wayfarer » Sun Mar 01, 2020 3:29 pm
leap day ! Went for a little putt Longest one yet - 3.2 miles round trip :lol: , and then ordered more parts. Lots of work coming in March. Hope to have her pretty well roadworthy by the end of March
