High Compression Pistons
Posted: Fri Feb 01, 2019 8:21 pm
Looking for opinions/input of those who have tried/experienced High compression pistons.
These are some comments from the old forum of some who have HC pistons.
By Mike Walker, NW AR on Monday, August 24, 2015 - 08:53 am:
I like using H-C pistons and milling the head if I'm building an engine anyway. If your engine is staying in the car, it's easier to change the head. Either way will get you higher compression and a more powerful engine. The high-comp piston/milled head route is less money than a new high-comp head (about half as much), and you still have a stock-looking engine with a cast iron head.
By Verne Shirk on Monday, August 24, 2015 - 07:16 pm:
I put HC pistons in the engine on a 1914 Touring we tour heavily. It runs nice and sounds good. They have been in the car since about 1998. No problems what so ever.
By Gary London, Camarillo, CA on Monday, August 24, 2015 - 09:02 pm:
I agree with Mike. I put the HC head on my car that already had a good engine, but installed HC pistons and stock heads on the engines I've either had to re-ring or rebuild.
By Robert A Weitzel on Thursday, November 17, 2016 - 11:32 pm:
I've ran the Hc Pistons with a low head. It had tremendous low and mid range torque not much top end though
By James A. Golden on Monday, March 10, 2008 - 09:44 am:
Domed pistons raised my compression ratio from 50 to 75 psi. The engine was rebuilt at the same time and some of the raise was from a shaved head and block top.
The difference in top speed was more pronounced. It went from 40 to 70 mph and the T was never opened up full, due to stopping again or likely rolling over from the quick steering or a blowout.
By David Dare on Sunday, January 03, 2010 - 08:16 pm:
l am using the domed HC PISTONS with a little head modification and cam mod, with the bigger breathing inlet manifold, in my wife's 26 Tudor, with very favorable results, The results are not as different as you are lead to believe.
If you want to retain that original look from the out side, this is the way to go, if you dont care, either or.
By Jerry Hansen on Monday, October 20, 2008 - 09:38 pm:
I have one car with, high domed pistons, Chevrolet valves and a Chaffin reground cam. This was done way before the heads and cams we now have were available.
The engine is installed in a 25 Coupe which runs along decently, but comparing it to other engines I have with aluminum head and either a Stipe or Chaffin cam along with a couple other things, it defiantly takes a back seat.
By Steve Boyd on Tuesday, October 21, 2008 - 08:03 pm:
I routinely shave 0.100 inches off the original head and install domed pistons on rebuilds. This system works fine as far as fit and clearances go. I have a side-by-side comparrison of this configuration with a 280 high lift cam and a stock cam and the high lift outperforms significantly!
By Keith Gumbinger, Kenosha, WI on Saturday, July 28, 2012 - 11:17 am:
In my 4 Model T's, I have one with the high domed pistons, 1 with a Z head, and 1 with a Chaffin (Reeder) high compression head.
In my experience the Z head is the best as it gives more power than the others. Further, I would not use the domed pistons again as the low rpm power from them is lacking.
Just my opinion and experience, others may vary....
By Mike Walker, NW AR. on Thursday, January 22, 2009 - 09:35 am:
"Most people" might be unhappy with domed pistons, but I'm not. I built a "new" engine for my '15 Touring just before the Richmond trip last July. I wanted it to appear stock on the outside, so I used an original Ford low head milled 1/8" with domed pistons. The previous engine has flat-top pistons and a Reeder 6:1 aluminum head. All other components were the same: Stipe 250 cam, Anderson timer with Ford coils, Simmons straight-through carb on an early aluminum manifold, etc. I have put 3,500 miles on the new engine since last July. There is one long hill I drive up from time to time, and I can now go up and over it without downshifting. I could not before, so apparently the new engine has more torque than the previous one. I have heard several folks bad-mouth domed pistons, but I am quite happy with them.
By David Dare on Saturday, October 15, 2011 - 12:01 am:
I'm a avid fan of domed H/C pistons, sorry, l love em and will continue to do so, l have had a Z head, passed it on. The difference is not chalk and cheese.
By Mike Walker -- NW Ark. on Saturday, October 15, 2011 - 11:29 am:
I have used high-compression heads as well as high-compression pistons with milled stock heads. Both routes will give you noticably more power and torque, and I really can't tell any difference in performance between the two.
If you're rebuilding an engine, the pop-up pistons and milled stock head are a bunch less money than a Z head. If you're not rebuilding the engine and want a bolt-on bump in power, the high-comp head is easy to accomplish.
By Verne Shirk on Saturday, September 12, 2009 - 11:33 pm:
I've used domed pistons with a high head and the engine runs very nice. I've had no problems in 15+ years of use. I like 'em!
By J and M Machine Co Inc on Saturday, March 04, 2017 - 05:25 pm:
We use them on a regular basis during rebuilds.
