band material?
Posted: Sun Feb 09, 2020 12:06 pm
by Craig Leach
Found this in some T parts I bought along time ago. Is this band material its 1.71 wide and .169 thick. Thanks. Craig
IMG_1403 (1).JPG (20.48 KiB) Viewed 4517 times
Re: band material?
Posted: Sun Feb 09, 2020 12:26 pm
by DanTreace
Too wide for narrow bands, too narrow for wide band ;)
Re: band material?
Posted: Sun Feb 09, 2020 1:13 pm
by Craig Leach
Hi Dan,
Yes it is narrower than the drum but is the same width as the wide band I have. Anyone have an idea what it is if not band material? thanks.
Re: band material?
Posted: Sun Feb 09, 2020 1:57 pm
by jiminbartow
I don’t think it is Model T band material. Looks more like antique oil lamp wick material. Jim Patrick
Re: band material?
Posted: Sun Feb 09, 2020 2:53 pm
by Steve Jelf
Gas tank padding?
Re: band material?
Posted: Sun Feb 09, 2020 5:46 pm
by Wayne Sheldon
Looks to me like too dense of a weave to be lamp wicks? Looks a bit thin to be T band material? Such woven belting was used for many hundreds of uses! It may have been for use on some non-Ford open transmission? Likely not. Gasoline tank padding? Likely. Similar belting used to be available in bulk in dozens of common sizes, for hundreds of uses. That close in size? I would be surprised if it wasn't used as a "make do" for a T's bands a few times. I wouldn't recommend it for that now however.
Re: band material?
Posted: Sun Feb 09, 2020 6:38 pm
by Duey_C
BIG lamp if so... ;)
Re: band material?
Posted: Sun Feb 09, 2020 6:42 pm
by perry kete
I thought this was band material...
Re: band material?
Posted: Sun Feb 09, 2020 11:19 pm
by Wayne Sheldon
Is that Sousa?
Re: band material?
Posted: Tue Feb 11, 2020 8:13 pm
by Craig Leach
Thanks everyone I think I will put it away for now. I'll save it for for an emergency. You never know there may be something to the zombie apalypse. ;)
