Engine noise
Posted: Sat Feb 02, 2019 8:42 pm
by TonyB
Some months ago the crank in my 14 Touring broke. Eventually I replaced it with a Scat but the engine was noisy. To my ears it sounded like a camshaft noise. I checked the end play, only a couple of thou thanks to the Chaffin Kit that mounts on the front lof the cam gear wheel. With the upcoming tour in Sierra Vista, I decided I could not take the car with the noise so I kept looking
When you use the Scat crank with a four dip pan, the counter weights come very, very close to the sump and there is no space for the “U” shaped bars to hold the inspection cover screws. So I chopped the U bar in half and made two “J” shapes.
One just touched the counter weight. On the picture you can see the shiny bit
- Shiny bit on end of J bar
The camshaft looks fine, I can’t see any rubbing marks though the center bearing may be in wrong way round. So far I can’t find any documentation to which way it goes, but even so it does not appear to touch anything
By the way this gives you some idea of what I disassembled to find the problem.
Re: Engine noise
Posted: Sat Feb 02, 2019 8:48 pm
by Norman Kling
Is your crankshaft a standard T stroke? I have one in my 26 and don't have a problem. I would suggest that you grind just a little off the J shaped bar in the position the crank touches it.
Re: Engine noise
Posted: Sat Feb 02, 2019 9:39 pm
by Allan
There have been enough instances of this to warrant a warning tag attached to the crankshaft to check for such clearance. I know it's not the manufacturer's problem to check clearances, but a heads up to likely difficulties would make for good relations. I found one problem just hand cranking the motor on the stand. It was enough to prevent cranking! The one on my 1925 roadster had no such problems.
Re: Engine noise
Posted: Sat Feb 02, 2019 11:25 pm
by TonyB
I knew it would be tight but I’ve done other, starting with the speedster in the 90’s so I was careful. It must be very close as the noise changed when I push the clutch and with new Babbitt the play is probably 4-6 thou it does not make the noise on the starter and I had no problems cranking the motor.
I’ll lie under the motor tomorrow and decide how to proceed.
Re: Engine noise
Posted: Sun Feb 03, 2019 7:39 am
by Gonenorth
Is this a problem with only some model year blocks? I have a SCAT crank in mine and have absolutely no issues with it in my '26. Engine number dates it back to the second week of December 1925, So I would guess the motor was manufactured some weeks prior to that.
Re: Engine noise
Posted: Sun Feb 03, 2019 11:34 am
by RajoRacer
Tony - paragraph 480 in my 1925 original Ford Service book states "install the notch of the center bearing towards the rear".
Re: Engine noise
Posted: Sun Feb 03, 2019 12:25 pm
by TonyB
Thanks for the position of the notch in the center bearing. I don’t see it in the MTFCA Engine booklet.
By the way, the crank I installed in the Speedster was the one from New Zealand as SCAT was not then available
Re: Engine noise
Posted: Sun Feb 03, 2019 3:00 pm
by AndreFordT
Did you check the rod bolt heads of the second piston at the camshaft side.
Last year someone brought me an engine with a strange knock. The owner did an overhaul with new crankshaft new rods new pistonsand rings new valves and seats . Since the rebuild there was a knock he couldn't find.
This what I found:
Good luck
Andre
Belgium
Re: Engine noise
Posted: Sun Feb 03, 2019 7:20 pm
by Adam
My top two suggestions:
1) Crank still is tapping the reinforcement.
2) Rod bolt head is tapping against the cam (Especially if you are using new bolts. Often the heads are too tall.)
Re: Engine noise
Posted: Sun Feb 03, 2019 7:59 pm
by Randall strickland
I installed a scatt in a 3 dip,I bolted the u bars in without inspection and rotated crank, crank was hitting the rear u a tiny bit so I marked and remove u and ground some clearance
Re: Engine noise
Posted: Mon Feb 04, 2019 11:51 am
by TonyB
I looked back in my notebook and on the three dip pan of the speedster, the rear inspection pan bolt hit the crank. I cut the U bar into two Js and brazed a bolt into the rear center hole.
I suspect that over the last hundred years the pans get slightly distorted and the fixtures only check the bolt patterns and NOT the depth of the pan. By the time I know everything about Model Ts, I’ll be too old to do anything with the knowledge
Re: Engine noise
Posted: Mon Feb 04, 2019 9:52 pm
by TonyB
I fixed the clearance between the counter weight and the J (were U) irons and put it all back together and the noise has gone.
Now to get the car ready for the Sierra Vista tour. I’ll take the torque wrench so I can check the torque on the cylinder head during the tour.
Re: Engine noise
Posted: Tue Feb 05, 2019 11:53 am
by Norman Kling
Glad your engine is fixed and ready for the tour. Have fun.
Re: Engine noise
Posted: Tue Feb 05, 2019 3:16 pm
by SurfCityGene
Tony, Have a Safe Trip. We'll see you there!
Re: Engine noise
Posted: Tue Feb 05, 2019 5:25 pm
by Steve Hughes
Glad you got it fixed for Sierra Vista. I will see you there.
