Rear diff roller thrust bearings.
Posted: Tue Feb 11, 2020 5:16 pm
by Dennis Prince
The other day I had a young fellow near me ask what I knew about the rear diff roller thrust bearing and I hadn't even heard about them, I checked and Snyder's has them but I still know nothing. Does anyone have any experience with or know about these? Thanks, Dennis
Re: Rear diff roller thrust bearings.
Posted: Tue Feb 11, 2020 6:08 pm
Been running a set in one of my Ruckstells for probably 20 years - hasn't "come from together" yet !
Posted: Tue Feb 11, 2020 6:52 pm
by jab35
There are a number of previous posts on the Forum, this one seems kind of neutral. I do not have a preference, best, jb
http://www.mtfca.com/cgi-bin/discus/sho ... ost=585188
Posted: Tue Feb 11, 2020 7:32 pm
I think they are an unnecessary complication, with a major drawback. The only way you can make adjustments to set crown wheel and pinion mesh is by fitting shims behind the thrusts. I'd much rather work with bronze thrust which can be manipulated to get a near prefect setting.
Others may differ.
Posted: Tue Feb 11, 2020 8:17 pm
by Stephen_heatherly
The roller bearings are completely unnecessary. The bronze thrust washers are cheaper and much less likely to give you trouble.
Stephen
Posted: Tue Feb 11, 2020 8:23 pm
by Les Schubert
If you have a POWERFUL T engine and aren’t running a Ruckstell then I like them. I installed them 40 years ago in a 60 HP speedster
