Question on starter switch mounting
Posted: Sun Feb 16, 2020 10:45 am
by namdc3
Is the mounting plate supposed to be on the top or the bottom surface of the upper rail edge on a fall of 1924 (1925 model) runabout? Shown here on bottom, which I think is correct.
Re: Question on starter switch mounting
Posted: Sun Feb 16, 2020 11:25 am
Chose your poison. They've been found both ways, though the manual shows them mounted "under" the frame edge.
http://www.mtfca.com/discus/messages/70 ... 1502580946
Posted: Sun Feb 16, 2020 1:07 pm
looking at where the pedal comes thru the lip on the front seat frame, looks a little on the short side now. I think I would move to top so your heel doesn't bottom out on the lip before the switch makes good contact inside.
Posted: Sun Feb 16, 2020 3:21 pm
by namdc3
Thanks, both.
