Rear end questions
Posted: Mon Feb 17, 2020 8:54 am
Hello Gentlemen,
With the help of the club workshop, the Ruckstell was able to go back together.
I put the axle tube half's together with just the paper gasket.
Is this ok? or should I have used a sealer? My concern is that, it seems that the tolerances are very tight and I don't want to mess things up.
For instance adding the paper gasket/spacer to the pinion bearing was just enough to bring it into alignment.
Do I need a gasket around the Ruskstell shift block?
I didn't get one with the gasket set. I might have ordered the wrong set.
When I pulled the U-Joint from the axle, the pin came out in three pieces.
Did I do something wrong with the pining of the end?
Here is the pic of the pieces.
