Bendix bending the stake washers?
Posted: Wed Feb 19, 2020 10:49 pm
by ivaldes1
Hi all, by what method does a Model Ter bend the tabs of the stake-washers on the Bendix? I find it very awkward and difficult to get to.
-- IV
Re: Bendix bending the stake washers?
Posted: Wed Feb 19, 2020 11:35 pm
by Kevin Pharis
I always resort to channel-loc pliers for this job. Roll the tab down as you squeeze... easy work!
Posted: Thu Feb 20, 2020 7:45 am
by Humblej
Pliers to start, punch and hammer to finish.
Posted: Thu Feb 20, 2020 10:34 am
by Original Smith
First of all, you have to have the bendix out of the car!
Posted: Thu Feb 20, 2020 11:11 am
by Mark Gregush
You have to bend the tab for the outside screw with the Bendix in the car no matter what, the inner one can be done outside. The replacements are harder then originals so do take a little more work. I use vice grips and kinda rock them into place then squeeze them up tight to the flat.
Posted: Thu Feb 20, 2020 11:27 am
by DanTreace
Normally a little starting bend with single slot screwdriver blade, levered against the spring loop.
Finish the flattened bend against the Bendix bolt with narrow width angle jaw 10" slip joint (Channel Lok) pliers, opposite jaw on backside of bolt.
- IMG_3773 (700x647) (600x555).jpg (148.63 KiB) Viewed 2889 times
