Anderson Timer question
Topic author - Posts: 302
- First Name: Bill
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
- MTFCA Number: 22487
- MTFCI Number: 17887
Which part of the flat contact gets touched by the flapper first? The butt end or the ramp?
- Attachments
- Anderson Timer
- IMG_2.jpg (51.07 KiB) Viewed 4299 times
- First Name: Ronald
- Last Name: Patterson
Re: Anderson Timer question
Ramp
The camshaft turns counterclockwise.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
The flapper contacts the end of the segment first and then rides down the ramp.
(The cam turns counter-clockwise if you are standing in front of the car. The cam turns clockwise if you are sitting in the car.)
- First Name: Bill
I agree. But that doesn't answer my question.
I am assuming that you are looking at the camshaft and flapper from the front of the engine to get the counter clockwise turn?
- First Name: Bill
Like this? Keep in mind that this view is reversed from what we normally see.
- First Name: Adam
- MTFCI Number: 1
Yes, that is correct.
- First Name: Bill
All of my Model T life I have assumed that the flapper touches the ramp first, then "flaps" off the butt end to get ready for the next strike. That just seems more logical to me. Now, a project that I'm working on has me looking closely at the mechanics of the timer, and I thought "no way". After talking to several others their answer was - ramp first. So that is what brought up my question.
Thanks- Adam & Ron for your help.
- First Name: David
- Last Name: Dufault
- * REQUIRED* Type and Year of Model Ts owned: 1915
- MTFCA Number: 303
Boy, thoser 1st two answers make this old mind really, terribly confused.....two different answers from extremely knowledgeable people...
- MTFCA Number: 4838
- MTFCI Number: 115
Bill
Correct.
This is the 'normal' view of the Anderson flapper.
The flapper is a sliding, gliding contact rotor, unlike the roller type that have to spin at speed.
The flapper is a wipe contact, spring loaded.
Correct.
It makes good sense. The abrupt end of the ramp is timed so that the flapper hits each segment at the proper time for the spark.
Adam
Your right and I am wrong.
Ron Patterson
Ron Patterson
- First Name: Bill
Ron- the camshaft does turn counter clockwise, as you stated, if viewed from the front.
- First Name: Robert
- Last Name: Skingley
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout
- MTFCI Number: 23002
You can fill the cup with axle grease, that will keep it lubed, and you won't need to check it for years...That is what I learned from those who service the T's at the Henry Ford. They service them once a year after about 5,000 miles, I am not sure what they do at that point , they could just put new ones in but I don't know for sure...I serviced mine 5 years ago and only drive about 200 miles a year, the grease does not drip out with heat...
