Tobin Arp thrust facing tool
Topic author - Posts: 1319
- First Name: Les
- Last Name: Schubert
So I have been “commissioned” to copy my Tobin Arp thrust facing tool. It is a very nice design as you can move the cutting tool radially as it spins. The TA is 1-1/8” diameter boring bar.
Just wondering if any one else needs one.
I am contemplating making one also for myself that is on a 1” boring tool for my T line boring outfit
I know some people just face the cap in a lathe but I prefer having a full diameter thrust face
- First Name: Andy
- Last Name: Loso
- MTFCA Number: 346
- MTFCI Number: 119
Re: Tobin Arp thrust facing tool
Pictures, please.
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Les, I could be interested. I'd like to see your design. Would It be for a Tobin Arp TA 14 ?
- First Name: Les
Bill
Yes for a TA 14
Yes for a TA 14
- First Name: Erik
- Last Name: Barrett
Les, I would like to have one for my TA14. Count me in.
- MTFCA Number: 52564
I know if you have to ask how much it cost you can't afford it, but I am going to ask anyway. Would it work with the KR Wilson boring bar?
When I had my block done it got the full face thrust also.
1920 Dodge touring
1920 Dodge touring
- First Name: Les
Bill and Eric
Thank you I will put you on the list
Cost
So far I am sourcing the components and talking to shops that can help with the project.
A project like this reminds me of the old joke;
“It’s a bit like buying hay, if you want top quality you need to pay a fair price, if the stuff that has been through the cow once is good enough, well that is considerably cheaper “!!
Cost
- First Name: Les
- Last Name: Hatch
- MTFCA Number: 49974
Les: Will parts be available? Will your parts work with an original? I have part of one. Thanks Dan
- First Name: Les
Dan
My plan is to make it functionally identical. The tool holder will be identical for sure as well as the controller.
I don’t want to disassemble the original one so I will guess a bit on the internal design.
I have finally succeeded in finding sources for the components and materials. Now to finalize the drawings!!
- First Name: Garland E
- Last Name: Pobletts
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Hey all,
Forgive my ignorance. Kinda new to the repair end of a T. What is this tool used for?
- First Name: Les
Garland
The crank bearings of old engines are generally poured Babbit which is machined in place to fit the crank. One of the bearings (usually the rear one) controls the end float. This is a cutting tool for facing these surfaces.
I hope this helps
I hope this helps
Got it. Thanks.
- First Name: DAN
- Last Name: MCEACHERN
- First Name: Les
Dan
I saw that one last night. Unfortunately it is missing a part (which I see is advertised separately for $600.00), the “stability disc”(I will call it that)!
I have finally sourced the components that I can buy. Now to complete the drawings and start making the other bits. It appears that probably I should make twice as many tool holders and “stability discs”, as tool holders for sure get “lost “ over the years.
Right now it seems like 3 complete assemblies.
My target is about $1,000.00 each, but we will see!
- First Name: DAN
The official name for the "stability disc is "Tool Holder Assembly" and the current part number was TA-950. The old part number for this was TA-B1130A.
As you probably know its serves two purposes- 1) a stabilizer for the facing tool and 2) a tool extension for large bores that were past the range of a long toolbit. With the tool mic at zero and on the extension, the tool would be set for a 4.125" bore or thereabouts. It seems odd, but my TA-14 manual has no mention of the Tool Holder Assembly or its use.
