Convert Kerosene lamp to electric.
Posted: Mon Feb 24, 2020 1:50 pm
by Chris Haynes
I am looking for something like this to hold a dual filament bulb.
Re: Convert Kerosene lamp to electric.
Posted: Mon Feb 24, 2020 5:17 pm
by Allan
Chris, I made mine using light sockets from 80's Japanese tail light assemblies. any later than that and the lights are all plastic. I bent some fencing wire for the ring and left a leg on one end to get the globe holder in the centre of the lamp. The metal socket was then soldered to the leg. I left the burner assembly in place, so had to feed the wiring through the lamp chimney.
Posted: Mon Feb 24, 2020 5:23 pm
by dmdeaton
I think Bob just posted a new LED conversion for these in the classifieds
Posted: Mon Feb 24, 2020 9:58 pm
by Chris Haynes
I have seen the LED's that Lang's has. Battery powered and no brake light.
Posted: Mon Feb 24, 2020 10:03 pm
by Chris Haynes
I'm not finding anything in the classifieds
Posted: Tue Feb 25, 2020 5:00 am
by Kaiser
I made these some time ago, to convert my side lamps to blinkers with LEDs, took a block of i think nylon and made it the same height as the burner assembly, that way the tank holds it in place, the wires go out the slot where the fegulator knob normaly goes, you don't have to butcher a good sidelight and you can convert back to kerosene in about two seconds, only thing is you have to find a way to make the wires look inconspicuous (did i spell that right ??) :roll:
Posted: Tue Feb 25, 2020 11:29 am
by RajoRacer
You just need one to convert the tail lamp ? I might have the one that used to be available some years back - still in the package - just need to locate it !
Posted: Tue Feb 25, 2020 12:54 pm
by AndreFordT
Here is how I did mine.
Lamp is 5/21W 12V.
Wiring enters by the chemeny, no hole was drilled.
Andre
Belgium
Posted: Tue Feb 25, 2020 2:45 pm
by dmdeaton
https://www.mtfca.com/phpBB3/viewtopic.php?f=5&t=10705
my bad, these are for converting carbide headlamps
