Pedal Shaft Seals
TBill
First Name: Bill
Last Name: Obier
MTFCA Number: 28973
Pedal Shaft Seals
Post by TBill » Tue Feb 25, 2020 7:19 am
What’s the consensus on O ring seals on pedal shafts in the hog’s head?
Do it or don’t?
If so, how best?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Pedal Shaft Seals
Post by Henry K. Lee » Tue Feb 25, 2020 8:02 am
Keeps them from leaking that is for sure!
Just Sayin'
Post by Scott_Conger » Tue Feb 25, 2020 10:06 am
Sealing the shafts is a good thing IF you understand that the prevailing trick using O-rings will starve the low pedal shaft of lubrication. It's an inelegant ad-hoc solution relying on uncontrolled compression of the o-ring.
A better solution is to machine the outside of the hogs-head bosses for small lip seals.
In either case, you will also want to watch your reverse and brake cams to see if they get any, or enough oil, or have to provide additional lube as necessary during operation.
Post by TRDxB2 » Tue Feb 25, 2020 11:26 am
..... In either case, you will also want to watch your reverse and brake cams to see if they get any, or enough oil, or have to provide additional lube as necessary during operation.
Point well taken. Not indicated on the lube chart.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Tue Feb 25, 2020 11:38 am
Lead in paints and gasoline, asbestos as fireproofing and in friction linings, talc (soapstone) to lubricate inner tubes and in baby powder, oil leaking from automobiles. All commonly encountered fifty years ago, and certainly in the heyday of the Model T. The current generation goes into paroxysms of fear for their lives at their very mention, as if they were to encounter the Black Death, or perhaps more apropos, Ebola or Corona viruses.
Perhaps rightfully so, but from the beginning, Model Ts leaked oil, which was actually to their benefit (within reason). One might as well study on how to keep one’s horse from defecating. :roll:
"Get a horse !"
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Feb 25, 2020 11:45 am
I think there is enough of a chamfer on the cams to allow for an O ring?
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Feb 25, 2020 11:52 am
I’ve done it on three engines and well worth the small effort. Larry, I didn’t find the chamfer large enough, but a couple seconds with a large countersink does the trick. It’s a good time to replace the hogshead pedal cams, and the ones supplied by Snyder’s are a fabulous reproduction. Some of the nicest reproduction parts I’ve ever seen.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Tue Feb 25, 2020 12:01 pm
Good timeing on this thread as I was wondering what to do in a few weeks when I get to the hogs head on my speedster.I had already about decided to let the dang thing drip if it wanted to as I have taken the pedal shafts out of 1 hoghead once and it was a pain in the "backside".
Dropacent
Last Name: Morsher
OIL. Pedal Shaft Seals
Post by Dropacent » Tue Feb 25, 2020 12:02 pm
And yes, Scott, that’s part of my small oil can routine. Good thing I have a handy dandy spring loaded oil can bracket holding my oil can under my hood ( or headbolt ) ;-)
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Tue Feb 25, 2020 12:35 pm
Here are the shaft seals I put on mine.
Respectfully Submitted,
Be_Zero_Be
For every Absolute Model T Fact there are at least three exceptions
You never used to be older :shock:
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Tue Feb 25, 2020 9:07 pm
I have used a large tapered reamer and chamfered out the pedal cams and used regular O rings in the past.
Bob, please tell us about the seals you use and your installation technique.
Keith
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Board Member Since: 2010
Post by Charlie B in N.J. » Tue Feb 25, 2020 9:33 pm
Clean the metal around the shaft extremely well. Perhaps brake cleaaner or some such degreaser. Lightly lube the shaft then apply silicone sealer around the shaft & on the surrounding metal. The silicone wont stick to the shaft but should adhere t the caseing metal if properly cleaned. Let it set up and I'm betting you'll end up with the chepest easiest stop leak fix. Not sure how long it'll last but maybe worth a shot.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Tue Feb 25, 2020 11:48 pm
A machinist friend put them in a 4-jaw and cut the recess for the seal.
The seal is a snug fit installed with Loctite.
It's good to have friends with skills. :D
Be_Zero_Be
TBill
First Name: Bill
Last Name: Obier
MTFCA Number: 28973
Post by TBill » Thu Feb 27, 2020 7:55 am
THANKS ALL!!!
And be sure to put a tarp under that horse.
