Speedometer cable fell off.
Topic author - Posts: 25
- First Name: Curtis
- Last Name: Fesler
- * REQUIRED* Type and Year of Model Ts owned: 1923 Fordor
Yesterday I went for a drive and noticed my speedometer quit working. Its on a 1923 Fordor. When I put the car away I could see that it slipped off and was laying across a tie rod and appears to be undamaged. I see the worm gear and it looks good. I haven't waded through the grease yet to see how its attached or how to put it back on. Is there a magic trick to make it stay on?
- First Name: Stephen
- Last Name: Heatherly
Re: Speedometer cable fell off.
It should have a nut that screws onto the output of the swivel drive.
Stephen
Stephen
- MTFCA Number: 52564
Make sure the slot and key are lined up when you screw the nut back on.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 14972
- MTFCI Number: 15411
Can you post a photo ? Some Stewart drives had a tapered pin holding the swivel halves together rather than a threaded bolt & nut.
