Front floor board
Posted: Fri Mar 06, 2020 11:46 pm
by Touring
What is the easiest way to make your own front floor board.. 1924 Ford Touring. Thanks for the help
Re: Front floor board
Posted: Fri Mar 06, 2020 11:54 pm
Borrow one and copy it.
Posted: Sat Mar 07, 2020 1:52 am
by sportbingo
I first made a template out of cardboard. I shaped the cardboard using a band saw and drill hole. After, creating a pattern I used it to make my wood floor.
If you need more information contact me.
Art Taylor
Posted: Sat Mar 07, 2020 7:24 am
by Touring
Thanks for the imformation, my problem is my motor is in another state being rebuild. It won't be back till end of the year. I am trying to have the car finished when it get back. That why I can't make a pattern. I thought there might be a blue print out their. This is my first t project.
Posted: Sat Mar 07, 2020 7:29 am
by Touring
Posted: Sat Mar 07, 2020 8:35 am
by CudaMan
Posted: Sat Mar 07, 2020 3:46 pm
by jab35
Jim: Here is a print of the bottom board, the one in front of the seat, from the Funprojects website. I suspect this one is the 'easiest' one to make. best, jb
http://www.funprojects.com/pdf/T1404B.pdf
Posted: Sat Mar 07, 2020 6:46 pm
by tdump
Art,where were you a couple years ago with that "tip'? :D I scratched my head bare trying to figure it out and finally just decided 1 day to lay some boards together,make it way to wide and trim it down.
Posted: Sat Mar 07, 2020 8:08 pm
by sportbingo
My son and I glued the board together and trim the board using the pattern. Good luck Jim.
Art
Posted: Sat Mar 07, 2020 10:41 pm
by Dan B
The best way is to buy them from Jon Anderson. They are exact to the factory specs and fit perfect.
Posted: Sun Mar 08, 2020 9:25 pm
by George Hand
Jim, I would like to ask did you not have a floor boards when you acquired your car?
Something I have seen is a pre 1925 T that has had a 1926-7 pedals, transmission cover or even a complete engine assembly. The pre 1925 pedals can be bothersome because they are narrow. I am saying this because the pedal spacing on the 1926-7 is different and requires a custom floor board.
Posted: Wed Mar 11, 2020 12:33 am
Getting them from Jon is the best idea. If not, find originals to copy, and be sure to rabbet the front and back sides. They were never varnished.
Posted: Wed Mar 11, 2020 8:43 am
by Mark Nunn
Don't expect dimensional lumber to fit. For my '26 Runabout I had to plane the boards to 9/16" to fit into the body's flanges and under the front board hold-down. The white panel in the photo is a piece of 1/4" hardboard that I used as a template for the upper board.
Posted: Wed Mar 11, 2020 9:28 am
by Charlie B in N.J.
Here's mine made from Poplar. So close they'd only fit this car. Your problem is no eng/trans in place. I'd definitely wait for it to be back in place. Anything else would be a crap shoot.
