Looking for information on TT Rear spring bushings
Posted: Fri Mar 13, 2020 10:29 am
by FATMAN
Does anyone have the o.d. and I.d. dimensions on the rear spring and perch bushings for the TT truck, I think the spring one is split and the perch ones are not, 2 different O.D.'S thank you, Bob
Re: Looking for information on TT Rear spring bushings
Posted: Fri Mar 13, 2020 1:16 pm
by HPetrino
Bob,
I don't know the answer to your question, but I think there's a dimension you've overlooked. I believe the early TT rear spring perch was narrower than the later ones and used spacers on each side. The perch bushings in these early units would be shorter than the later perches and bushings which were the same size as the spring without the spacers.
Anyhow, that's how I understand it.
Posted: Fri Mar 13, 2020 2:15 pm
by FATMAN
If you measure both perches, the same bushing was used, the spacer takes up for the short perch, thank you, Bob
Posted: Fri Mar 13, 2020 10:47 pm
I would measure the shackle and measure the hole in the perch. I bet both of them will be a standard size, like 9/16 and 11/16 or 5/8 and 3/4, and the bushings would match. I hope somebody seeing this will have a bushing to measure.
Posted: Sat Mar 14, 2020 9:15 am
by FATMAN
I have the perch and bushing but no main leaf for the spring to go by, Bob
Posted: Sat Mar 14, 2020 9:35 am
by Andy Loso
Bob,
I'll see what I can scrounge up for you this afternoon. Heading out to the local T club work meeting.
Andy
Posted: Sat Mar 14, 2020 9:40 am
by FATMAN
Thanks Andy, Bob
Posted: Sat Mar 14, 2020 5:10 pm
by Andy Loso
Bore I'd is .937
Posted: Sun Mar 15, 2020 10:28 am
by FATMAN
Andy, is that the bore in the main leaf, also the bushing in the main leaf is it solid or split? Bob
Posted: Mon Mar 16, 2020 10:45 am
by Andy Loso
That is the of the main leaf, the bushing is solid
