Where & how much to lighten flywheel?
Posted: Sat Mar 14, 2020 12:11 pm
by Chris Bamford
We are replacing my speedster flywheel thanks to cracks from the triple-pin holes to the centre bore.
The current flywheel had been lightened somewhat (not in the area that cracked) and I plan to do similar to the replacement.
Very interested to hear others' opinions/suggestions/experience about where one can remove a fair bit of mass without compromising integrity.
I'm not worried about the flywheel being TOO light and thus affecting smoothness β the magnets add substantial mass and the whole setup will be balanced.
Re: Where & how much to lighten flywheel?
Posted: Sat Mar 14, 2020 12:18 pm
by Henry K. Lee
I have taken about 4 pounds off of them with magnets and about 7 pounds when using an accessory ignition with no issues. Sure does make them rev up quicker.
Posted: Sat Mar 14, 2020 1:03 pm
by Tbz4u
I would definitly balance flywheel after doing removal of material and the magnets... We knife balance them
Posted: Sat Mar 14, 2020 1:08 pm
Back in the mid to late eighties, there was an article printed in the Vintage Ford with a diagram on how to lighten the flywheel by a Canadian machinist, if I recall correctly. Prior to my learning lathe machine work, my machinist friend followed the instructions and I recall him removing 10 or 11 pounds - that flywheel is in my Racer w/full length A crank & BB RAJO and as Hank stated - she revs up real quick !
Posted: Sat Mar 14, 2020 1:14 pm
by Henry K. Lee
Definitely rebalance.
Posted: Sat Mar 14, 2020 2:20 pm
by Kevin Pharis
Itβs been a while so the the numbers are a bit fuzzy... but seems to me the stock flywheel weighs 30 lbs bare. I turned 15 of these pounds off, and have been abusing the remaining flywheel for the last 10 years or so... not sure I recommend going this far, but sure makes for a snappy motor!
If you are leaving the magnets on... Iβm not sure that you could remove enough weight to make a difference. Might not be worth the effort for just a few pounds, especially with the resistance of the magnets acting like pump impeller veins.
Posted: Sat Mar 14, 2020 2:45 pm
Had my crank & lightened flywheel spun balanced up to 4 K r.p.m. prior to final engine assembly - Zoom-Zoom !
Posted: Sun Mar 15, 2020 1:14 am
by Chris Bamford
Thanks to all for your comments. Much appreciated.
Posted: Sun Mar 15, 2020 7:49 am
by Ralph F
Chris I have a cut down fly wheel in the barn. I will try and get some photos and measurement and post them later today.
Fitz
Posted: Sun Mar 15, 2020 5:46 pm
by Ralph F
Here are two photo of my cut down flywheel. The diameter of the flywheel is about 10".
Fitz
Posted: Sun Mar 15, 2020 6:08 pm
by Kevin Pharis
I LIKE IT!!!
But... do you have pics of the cut down magneto to go with it???
Posted: Sun Mar 15, 2020 6:54 pm
by Ralph F
Kevin this all got when I bought my speedster.
Fitz
Posted: Sun Mar 15, 2020 11:25 pm
by Chris Bamford
Thanks for those pics Ralph. That is quite the flywheel β gonna be tough to mount my magnets though...
