Wind wings
Russ T Fender
First Name: Val
Last Name: Soupios
Wind wings
Post by Russ T Fender » Mon Mar 16, 2020 7:03 pm
Does anyone have the dimensions for the glass? I guess I can fudge it but I'd rather get it right! Thanks.
Dropacent
Last Name: Morsher
Re: Wind wings
Post by Dropacent » Tue Mar 17, 2020 8:58 am
Val, I think jack Putnam, bluffton Ohio has it. Good luck, great accessory
MTFCA Number: 4838
MTFCI Number: 115
Re: Wind wings
Post by DanTreace » Tue Mar 17, 2020 8:58 am
While no glass dimensions are given in the Service Bulletin, you might get close to extrapolate them from the sketch and measures of the clamp placements.
MTFCA Number: 4838
MTFCI Number: 115
Re: Wind wings
Post by DanTreace » Tue Mar 17, 2020 9:06 am
This new 1926 touring has the wind wings fitted, photo may help too.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: Wind wings
Post by Russ T Fender » Tue Mar 17, 2020 10:14 am
Thanks for the information. I think I have a template on the way!
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: Wind wings
Post by Ruxstel24 » Tue Mar 17, 2020 11:26 am
Say something if you don’t get a template Val.
I’ll go and measure mine and let you know if you need.
I believe my neighbor cut the glass, he might have a copy ?
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926
MTFCA Number: 29784
MTFCI Number: 22970
Re: Wind wings
Post by Mustang1964s » Tue Mar 17, 2020 12:05 pm
Russ,
Please post a picture and the dimensions when you get the template.
I would love to put a set of Wind Wings on my wife's cars.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: Wind wings
Post by Russ T Fender » Tue Mar 24, 2020 10:48 am
Steve, here is the template I received. I don't have access to my car right now so I can't hold it in place to see how it looks but it seems to be very close to the glass pictured in the Ford brochure posted earlier in this thread. The bottom of the glass is somewhat rounded on the template but I would probably make it parallel with the top. Hope this helps.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: Wind wings
Post by Russ T Fender » Tue Mar 24, 2020 10:58 am
Let me try that again!
Roffe
First Name: Rolf
Last Name: Oehman
Re: Wind wings
Post by Roffe » Tue Mar 24, 2020 12:24 pm
Hi. Took some pictures of my 26 roadster. Seems the sides are parallel sideways and up-down. 200mm X 440mm.
