26-27 license plate clamps
Posted: Fri Mar 20, 2020 3:44 pm
by GG Gregory
Are the 26-27 license plate clamps that mount to the headlight bar the same as for a Model A ? I have a set for a Model A but the holes in the original 1927 Tennessee plate are set lower and I can’t attach it.
Re: 26-27 license plate clamps
Posted: Fri Mar 20, 2020 3:52 pm
by Dropacent
Same as the model A. Look for genuine ones, the reproductions are crappy
Posted: Fri Mar 20, 2020 3:58 pm
by Humblej
Anyone have an original they can post a picture of?
Posted: Fri Mar 20, 2020 4:21 pm
by GG Gregory
Thanks, now to find a set !
Posted: Fri Mar 20, 2020 8:35 pm
by RajoRacer
I believe I have several sets - I'll look tomorrow.
Posted: Fri Mar 20, 2020 8:46 pm
by GG Gregory
RajoRacer, let me know if you have a set to sell.
Posted: Fri Mar 20, 2020 9:05 pm
by Norman Kling
The placement of the holes on the plate should not be a problem. The correct way to place the brackets is to put the bolt to the top of the bar and bolt the plate on the front, not between the clamps. So it should work fine if you place it this way.
Posted: Sat Mar 21, 2020 7:49 am
by GG Gregory
Thanks Norman I’m sure that would probably work but I’d rather Mount the plate the way it should be if possible.
Posted: Sat Mar 21, 2020 10:53 am
by DanTreace
Have found the reproduction A clamps to be satisfactory.
Here is Ford #15 millon with Ford accessory license clamps, note how they hang.
On this accessory bar, the clamps hang, and the bolt goes thru the license slot, period plate.
Or, if you found old aftermarket versions, they hang from the bar too. Plate below hanger.
And another old photo of period placement.
- 348170 (599x446) (2).jpg (113.6 KiB) Viewed 4056 times
Posted: Sat Mar 21, 2020 12:24 pm
by GG Gregory
Ahh, I see Dan! Thank you. I just assumed they should actually hang through the clamp itself like my 1930 Model A, guess not.
