1925-27 rolling chassis to TT?
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Wed Feb 06, 2019 12:02 am
Hi, I have a 1925-27 rolling chassis that I would like to build up into a T Truck. To start, how can I get a TT cab body and a bed? How do I get an engine?
-- IV
Raoul von S.
First Name: Raoul
Last Name: Vaughn
* REQUIRED* Type and Year of Model Ts owned: 1925 truck
Re: 1925-27 rolling chassis to TT?
Post by Raoul von S. » Wed Feb 06, 2019 12:27 am
Is your chassis a TT chassis ? While the front suspension is the same as the cars,
the frame and rear end/suspension is totally different.
What kind of cab do you want ? Aftermarket wood ? Factory C-cab ? Factory "box"
(closed) cab ?
What kind of bed do you want ? Flatbed ? Express bed ? Other ?
"Working today, for a seamless tomorrow"
Marv K
First Name: Marv
Last Name: Konrad
* REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
Board Member Since: 2010
Post by Marv K » Wed Feb 06, 2019 12:35 am
-Hi, Ivaldes-
Often misunderstood, "TT" is the nomenclature for "Ton Truck", indicating a more heavily constructed frame/chassis and load capacity. The wheelbase for a Model T was standard at 100", while the 'TT' wheelbase (at least for our TT stake-bed) is at 117" if I am remembering correctly. Many car chassis have been converted into various truck configurations. If you're planning for a pick-up style, the car chassis will work fine. You'll need to watch the classifieds and swap meets for parts. As Raoul stated, there are alternatives to consider. Good luck in your adventure
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Wed Feb 06, 2019 12:35 am
How do I tell if a chassis is a TT? Probably a factory box cab with express bed.
Marv K
First Name: Marv
Last Name: Konrad
Post by Marv K » Wed Feb 06, 2019 1:13 am
You'll want to identify 'what' you have. Measure your wheelbase for a start, also, the depth of the c-channel frame rails at the middle of the chassis are (thinking here) about 5" deep/tall, while the car and small truck rails are about 3" tall. You will quickly identify what you have.
Raoul von S.
First Name: Raoul
Last Name: Vaughn
Post by Raoul von S. » Wed Feb 06, 2019 1:23 am
Frame is tall and LONG, compared to a regular T frame. Rear wheels are thick and heavy.
Regular T's use the same wheels front and back. Rear end on a TT will have an over-the-top
worm gear input. T's have a more "normal"/modern looking rear end.
I can get measurements in the AM, if you like.
C-cab was introduced in 1923. This example wears the early TT 23" rear wheels, that look
more like the front wheels.
This example has the box cab, introduced in 1924 and wears the later (post-1924) 20" wheels
that look much heavier than the front wheels.
Raoul von S.
First Name: Raoul
Last Name: Vaughn
Post by Raoul von S. » Wed Feb 06, 2019 1:27 am
A number of people have installed TT cabs to regular T chassis. The T frame would be too short
to attach a factory TT bed, but as many T and TT trucks wore aftermarket cabs and beds, a
fabricated bed is nothing out of the norm, and with a little thought, could be done to look period
correct.
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Wed Feb 06, 2019 10:55 am
Igancio,
You may not be able to easily recognize if it is a TT frame unless a TT chassis and a car chassis are side by side or you have a tape measure, but an easy way to ID a TT chassis is by the rear end. The car rear end has the drive shaft in the center of the differential, the TT rear end has a worm gear so the drive shaft is on the top of the differential. Engines, cabs, and beds are around and can be acquired, but if you are missing that much it may be more economical to start with a complete truck rather than buy the individual parts and build one.
First Name: Jeff
Last Name: Humble
MTFCA Number: 28034
Igancio,
ChrisB
First Name: Chris
Last Name: Brancaccio
MTFCA Number: 443
MTFCI Number: 23136
Post by ChrisB » Wed Feb 06, 2019 11:23 am
Here is a link to a post on the 2012 forum, shows 2 car frames and a TT frame, not the best for comparison but will give you an idea.
http://www.mtfca.com/cgi-bin/discus/sho ... POST445569
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Wed Feb 06, 2019 1:57 pm
The reason to make the rolling chassis into a model t truck are sentimental, fun, and to advertise a business. There is a in project in pieces on the classified's and I plan to go to Chicksha so here we go... :D
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Wed Feb 06, 2019 2:13 pm
Frame is not a TT it is a regular frame. Will a C or box cab/express or flat bed fit?
First Name: Jeff
Last Name: Humble
MTFCA Number: 28034
Post by Humblej » Wed Feb 06, 2019 2:55 pm
As others have stated, a TT cab will fit a car chassis but a TT bed will not fit a car chassis.
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Thu Feb 07, 2019 11:59 pm
I see that Runabouts can be converted back and forth to a light truck bed by changing out the turtle deck so sounds like Runabout it is.
Raoul von S.
First Name: Raoul
Last Name: Vaughn
Post by Raoul von S. » Fri Feb 08, 2019 2:03 am
Model T's were made into every imaginable configuration and then some, back in the day.
Can you do the same ? Sure you can ! Your project is only limited by your imagination.
There is a fellow on this forum who built a pickup truck around a TT box cab. The proportions
were a little large for the cab, compared to a regular T truck, but it was cute as hell ! I think
he was trying to sell it, last time I heard.
Cabs can be found, as can beds. The frame of a T just isn't long enough to support a stock
flatbed, but that doesn't mean a guy has to go that route, or could not get creative.
The T has a lot more speed potential than a TT, without spending cubic dollars, so the T is
a lot more practical to drive, ... unless you want to toss a buch of money at a TT. But is sounds
like you have a T base to build on. Run with it !
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Feb 08, 2019 5:45 pm
Car chassis trucks were made back in the day, all wood bodies.
And some owners go all out to put Ford factory Ton Truck (TT) metal enclosed cab on the T car chassis too! Bed is car metal bed
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Sun Feb 10, 2019 12:22 am
Dan that last picture is just amazing how perfect it looks. I cannot imagine what it takes to get them to look that good.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Sun Feb 10, 2019 12:43 pm
Ignacio
Sure we can imagine, just takes $$ and some time, skills help, depending on how the finished T is invisioned :)
Another on T car chassis to view.....before and after of the green one. Today its fully finished now.
DSC00042 (600x450).jpg (61.98 KiB) Viewed 6747 times
IMG_6301 (800x494) (600x371) (579x358).jpg (66.72 KiB) Viewed 6747 times
