It looks like one wire wheel and one artillery wheel up front.
https://gallica.bnf.fr/ark:/12148/btv1b ... .r=voiture
Car torched in 1932 Athens transport strike
Topic author - Posts: 467
- Last Name: Guitar
- Board Member Since: 2012
- First Name: Rich
- Last Name: Bingham
Re: Car torched in 1932 Athens transport strike
A ‘26-‘27. Odd the front wheels would have been mismatched.
"Get a horse !"
- MTFCA Number: 4838
- MTFCI Number: 115
Also has accessory front spring support with 2 extra u clamps over the front crossmember.
As the rear hubs on the large drum axle are wire wheel hubs, one could guess that a tire got flat, didn't have a 21" replacement handy in 1932, so to keep going just pulled the wire wheel front hub, off the spindle, and mounted an old used wood wheel, looks like 30 x 3 1/2 , but that would be approx the same outer dia. Just bumpy ride
- First Name: Manuel
- Last Name: Voyages
Is that a rock resting on the rear spring?
Manuel in Oz
Manuel in Oz
