What Are these Parts?
Posted: Sun Mar 29, 2020 1:02 pm
by DontKnowMuch
These were with some speedometer parts but I don't know what they are. What are these parts?
Re: What Are these Parts?
Posted: Sun Mar 29, 2020 1:08 pm
by Fire_chief
The one on the left holds the windshield to the dash
Posted: Sun Mar 29, 2020 2:28 pm
by Rich Eagle
The one on the right could be a standoff for mounting a second spare tire. I found some for my Model A. It required 3 and replaced the lug nuts.
Does it have a threaded hole in the opposite end and the same size as the threaded stud?
Mine were simply made of hexagonal stock. Those are fancier.
Posted: Sun Mar 29, 2020 9:37 pm
by DontKnowMuch
I will check tomorrow about the threaded shaft end. No, it does not have a hole in the opposite end.
I will compare the other part with my windshield supports on my 1914 touring. Thanks for the suggestion.
Posted: Sun Mar 29, 2020 9:45 pm
James. to me the windshield brackets are for screens which mount straight up and down. The notches are set at the same height, and being brass, suit pre 1913 cars. For the 13-14 windscreens they were steel and one side was longer than the other to accommodate the slanting lower winscreen.
Hope this helps.
Posted: Mon Mar 30, 2020 9:31 am
by Colin Mavins
Looks the same as my 1912 windshield clamp
Posted: Mon Mar 30, 2020 11:51 am
The right one looks like a limiting stop for a non Ford spindle.
