Spare Tire Carrier Bolt Sizes, Mounting?
Posted: Sun Mar 29, 2020 5:22 pm
by ivaldes1
Hi, all getting ready to mount the spare tire carrier pictured lying upside down on the floor.
What size bolts do the 4 holes on the rear crossmember mount with?
What size bolts do the 4 holes on the top of the frame take?
The nut is missing from the bottom keeper bolt. What size/thread is that? Is it supposed to be a wing nut or something else?
Thanks in advance, -- IV
Re: Spare Tire Carrier Bolt Sizes, Mounting?
Posted: Sun Mar 29, 2020 6:22 pm
by John kuehn
I removed a spare tire carrier from a parts frame to mount on my 24 Coupe. They were 3/8” fine thread bolts and nuts like the majority of bolts used on a T. Seems like they were 1 1/2” long. What ever length they were it was long enough for a nut and lock washer and 1/4” past the nut when tightened. That’s as I remember. Maybe somebody has the right answers for that if I’m wrong.
Posted: Sun Mar 29, 2020 6:38 pm
by DanTreace
John posted what I was to do, just a 3/8" dia, fine, use lock washers, hex head, hex nut, fine thrd. bolts are stronger. All are the same size.
The rim is held by the threaded stud, thru the clamp, with a flanged style nut, so that it grips best. The upper holes are for locking means, a chain around the tire and rim or what ever you need for the neighborhoods you plan to leave the T on the street overnight :lol:
Posted: Mon Mar 30, 2020 11:27 am
by John kuehn
Dan on your last post the rim looks like a new rim. Very nice in the close up. Just wondering if it is.
Posted: Mon Mar 30, 2020 11:44 am
by DanTreace
John
Could be a new rim, looks super nice....however, not mine. Photo snagged off older forum posts...can't give credit as didn't retain who posted.
Here is mine, original rim, alum spray paint for shine :D
Non-original piece of black foam plastic for anti-rattle. ;)
Posted: Mon Mar 30, 2020 11:50 am
by John kuehn
Mine look like yours also Dan! Thanks.
Posted: Mon Mar 30, 2020 1:10 pm
by namdc3
Dan, thanks for these two photos. It clears up a question I've had for awhile. Most people are missing the clamp piece and they just align a lug to the hole on the frame and bolt through it. I've looked at factory photographs to see what was right but I hadn't seen what I was looking for.
Posted: Tue Mar 31, 2020 12:33 am
by ivaldes1
Good to know what the other hole in the clamp does. Say the 3/8 ths OD is too big 5/16th's fits...
Posted: Tue Mar 31, 2020 10:25 am
by DanTreace
Your are correct on the 5/16"x 24 thrd. Parts book shows length as 11/16", but some additional length is needed for certain body styles, date of this Service Bulletin is Aug, 1921.
These earlier carriers were slightly different than the later, esp. in the crossbar design to hold the license plate and taillamp. Of course the '26-'27 got completely different rim carriers.
Posted: Wed Apr 01, 2020 12:26 am
by ivaldes1
It is on!
It sat in the garage for two years waiting to be installed after I bought it from George House. It took 8 5/16ths 24 thread 1 inch bolts. The FLAPS only had flange head and nuts in that size but I think that is probably better than a regular bolt. The 4 internal bolts that go on the top of the carrier and into the chassis beam are tough to get to. Putting a lock washer is even more difficult under those circumstances. I am glad to get it done after all this time sitting in the corner.
Now I only need the size nut for the bolt that holds the lower clamp on.
Posted: Thu Apr 02, 2020 11:41 pm
by ivaldes1
And the nut size for the stud bolt is...the exact same as a demountable lug nut and probably should be a demountable lug nut!
