Anyone making lever extenders or reverse pedal extenders?
Topic author - Posts: 26
- First Name: len
- Last Name: doyle
- * REQUIRED* Type and Year of Model Ts owned: 1927 tourer 1925 roadster
Hi Guys,
I would quite like to contact anyone who is able to supply a few handbrake lever extenders or a few reverse pedal extenders. Please message me.
Len
Len
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Re: Anyone making lever extenders or reverse pedal extenders?
Tom Strickling from New Philadelphia Ohio, USA, makes the pedal extenders.
All the vendors sell them. I think they're around $35. Very usefull.
- Last Name: Morsher
Let me know if this one would interest you. I can fix you up. Tmorsher@icloud.com
- MTFCA Number: 16175
- MTFCI Number: 14758
Here's a home made pedal extension using two inch square tubing.
If you have welding equipment it's easy to make.
- First Name: Jeff
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
- MTFCA Number: 25636
Antique T Motorsports sells the brake lever extensions through their ebay store.
- First Name: len
- Last Name: doyle
Thanks for the info. I like it all and will PM to pursue things.
- Last Name: Patrick
- MTFCA Number: 50126
I’m 6’-3”, 225 lbs. With my long legs, that pedal extender would render the reverse pedal useless to me. It’s hard enough for me to use the pedals without the steering wheel getting in the way of my knees. With my big feet, I’m just grateful I have a ‘26 coupe, equipped with the wider brake and clutch pedals. Jim Patrick
- First Name: Susanne
- Last Name: Rohner
- MTFCA Number: 464
I have one, I think I got it from Langs or Chaffins... it's a cast aluminum piece, and actually makes the old style pedals a little more intuitive, as you can index your C and B feet off the sides of the reverse extender... Since I don't spend that time going backwards (looking backwards, sure, but going backwards, not so much) it's not that big a deal.
