Ford accessory Stop/Tail light parts ???
Moxie26
Last Name: Jablonski
MTFCA Number: 407
Post by Moxie26 » Tue Mar 31, 2020 8:38 am
I'm looking for the reflector in the top stop light section. Is there anyone making reproductions? Or does anyone have parts available?
Last Name: Gregush
Re: Ford accessory Stop/Tail light parts ???
Post by Mark Gregush » Tue Mar 31, 2020 3:39 pm
The only repo part would be the gaskets. Keep your eyes on ebay they sometimes come up missing parts. Looks like Dodge and Hupp used them so branch your search out to include them. The parts would be the same just different stamping or lettering on the glass.
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=11618
1920 Dodge touring
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Tue Mar 31, 2020 8:25 pm
Mark gave the best approach, better than searching swap meets, esp. since for a while no swap meets :cry:
A Dodge Bros. Hall mfg tail lamp was poor shape, housing outer rusted and damaged, but sold in Feb 2020.
But who got it for $51 looks like got a decent rim, both lens, can see the stencil inside the red lens, and likely not had the reflector too.
Used eBay to search, found it in the completed auctions sold, you can see the closed listing by typing in the # below:
eBay item number:153837922913
Jim Bowery
First Name: Jim
Last Name: Bowery
MTFCA Number: 19036
MTFCI Number: 14288
Post by Jim Bowery » Wed Apr 01, 2020 6:07 am
New red glass lens and new Chrome rim is available from Tom & Cindy
Myers Early Dodge Parts,LLC
8201 Wadsworth Rd.
Ottawa Lake, MI 49267
1-734-856-1207
1-734-341-6139 Cell
Moxie26
MTFCA Number: 407
Post by Moxie26 » Wed Apr 01, 2020 7:39 pm
Thanks everyone for your response but I was referring to the curved glass reflective mirror or silvered metal reflector that goes behind the stop light bulb.
Last Name: Gregush
Post by Mark Gregush » Wed Apr 01, 2020 7:48 pm
Yes so was I. You will have to get a parts light to get the parts to make one out of two.
1920 Dodge touring
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Apr 01, 2020 9:36 pm
I had mentioned in the other thread that my dad had a 1927 Hupmobile with the same but Hall tail light.
I should have also mentioned that, six years ago, I had a Dodge Hall light but sold it on eBay.
Note that the reflector was missing but the interior was painted white.
White paint can be a temporary fix until you locate a reflector, Dodge or Hupp light for parts or a complete Ford script light.
Post by TRDxB2 » Wed Apr 01, 2020 11:19 pm
It might be possible to make a temporary one from a CD-ROM. I only spent a few minutes to see if it was possible. Cut the CD with a hot knife then laid it across a dish, use a heat gun to melt it down for a curve.
The CD had some printing on the back and that is what the reflection is showing through
The target
Colin Mavins
First Name: Colin
Last Name: Mavins
MTFCA Number: 1853
Post by Colin Mavins » Thu Apr 02, 2020 10:01 am
If you have the reflector and the problem is the reflective silver take same aluminum foil ,crunch it up than straighten it out and form it over the old reflector . this will make your tail light shine bright. Cheers Colin
Moxie26
MTFCA Number: 407
Post by Moxie26 » Fri Apr 03, 2020 8:38 am
Practical solutions appreciated thank you
Moxie26
MTFCA Number: 407
Post by Moxie26 » Fri Apr 03, 2020 6:03 pm
In a phone discussion with a fellow t-owner I will look into using a headlight reflector and using its curves cut a shape to fit behind the stoplight bulb in the combination tail light. I'll let you know of my progress
Last Name: Gregush
Post by Mark Gregush » Fri Apr 03, 2020 9:26 pm
Ah plans are made, sounds good. :)
1920 Dodge touring
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sat Apr 04, 2020 3:59 pm
Bob, I sent private message or email (can't remember which). I may have one to spare, but it probably isn't shiny.
Moxie26
MTFCA Number: 407
Post by Moxie26 » Mon Apr 06, 2020 8:17 pm
Terry, thank you but I haven't received either yet
Moxie26
MTFCA Number: 407
Post by Moxie26 » Wed Apr 08, 2020 11:28 pm
The plan to use silvered headlight reflector was canned since the metal is really substancial and difficult to shape into light housing. Still looking for an original reflector. Next thought was to use the reflective surface of the inside of a soda can,,,, will have time tomorrow to start that route.
Bob Jablonski
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Fri Apr 10, 2020 4:18 pm
Bob, Am sending email. If I get a reply, I'll know you got it. T. Woods
Moxie26
MTFCA Number: 407
Post by Moxie26 » Sun Apr 12, 2020 3:03 pm
Terry, e-mail received and appreciate your help !!
