My approach to pressure oil lines
Topic author - Posts: 1319
- First Name: Les
- Last Name: Schubert
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: My approach to pressure oil lines
Those are the good fittings!!
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Those are the BEST Fittings and a Nice job forming the lines!!
1912 Torpedo Roadster
Yes, they are the best fittings. Now, how many have seen the proprietary wrench(s) and gap gauge available for them and when should it be used and when should it NOT be used? Just a little trivia from someone who spent much of their career using them...
Les
nice work and no small task working with tha SS tubing...
Les
NH Full Flow Float Valves
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
What kind of fittings are they?
- First Name: Les
Swagelok. Not cheap but ultimately easy to use. Actually the tubing is just galvanized steel. The fittings are SS. Fortunately available off the shelf locally. Over the years we used a LOT of them at the shop I had.
- Last Name: Kelly
Nice looking work.
- Last Name: van Ekeren
Les.
I don't like being picky but I hate seeing things that can give a heap of grief down the track, your rods are around the wrong way and no oil holes in the pistons for the wrist pins.
- First Name: Les
Just about ready to light it up!!
- First Name: DAN
- Last Name: MCEACHERN
A different outside view. Did this one a few years ago. All stainless- the Swageloc guy loved me!
Wow Les, indeed he did!
That's a lot of pricey bling on display. The engine's not so bad, either!
- First Name: Susanne
- Last Name: Rohner
- MTFCA Number: 464
What are you using for an oil pump, and how do you have it routed? I'm way new to pressure oil, and would rather not cook a new and good block on my first foray....
- First Name: Les
I sent you a email
- First Name: Robert
- Last Name: Weitzel
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
- MTFCA Number: 22631
DAN how do the swagelok compare to the a n. Fittings
- First Name: DAN
AN fittings use a 37 degree flare as the sealing surface and were developed during WW2 as an Army-Navy (AN) spec for aircraft use. Swagelok tube fittings use a 2 piece ferrule similar to a commercial compression fitting but are manufactured to a much higher quality level, and are generally available in Stainless, brass and steel. They are used a lot in the chemical process industry and anywhere high reliability is needed.
