My approach to pressure oil lines
Posted: Sun Apr 05, 2020 2:35 pm
by Les Schubert
Connecting to outside
Front  main bearing (not really easy to see
Rear  main bearing
Rear main bearing
Line connection
Line connection
Re: My approach to pressure oil lines
Posted: Sun Apr 05, 2020 3:02 pm
by Joe Bell
Those are the good fittings!!
Posted: Sun Apr 05, 2020 3:48 pm
by SurfCityGene
Those are the BEST Fittings and a Nice job forming the lines!!
Posted: Sun Apr 05, 2020 4:11 pm
by Scott_Conger
Yes, they are the best fittings. Now, how many have seen the proprietary wrench(s) and gap gauge available for them and when should it be used and when should it NOT be used? Just a little trivia from someone who spent much of their career using them...
Les
nice work and no small task working with tha SS tubing...
Posted: Sun Apr 05, 2020 4:25 pm
by Shane Lach
What kind of fittings are they?
Posted: Sun Apr 05, 2020 4:33 pm
by Les Schubert
Swagelok. Not cheap but ultimately easy to use. Actually the tubing is just galvanized steel. The fittings are SS. Fortunately available off the shelf locally. Over the years we used a LOT of them at the shop I had.
Posted: Sun Apr 05, 2020 4:42 pm
by kelly mt
Nice looking work.
Posted: Sun Apr 05, 2020 5:07 pm
by Kerry
Les.
I don't like being picky but I hate seeing things that can give a heap of grief down the track, your rods are around the wrong way and no oil holes in the pistons for the wrist pins. :(
Posted: Sun Apr 05, 2020 6:38 pm
by Les Schubert
Just about ready to light it up!!
Posted: Sun Apr 05, 2020 11:22 pm
by Dan McEachern
A different outside view. Did this one a few years ago. All stainless- the Swageloc guy loved me!
Posted: Mon Apr 06, 2020 10:08 am
by Scott_Conger
Wow Les, indeed he did!
That's a lot of pricey bling on display. The engine's not so bad, either!
Posted: Tue Apr 07, 2020 7:42 pm
by Susanne
What are you using for an oil pump, and how do you have it routed? I'm way new to pressure oil, and would rather not cook a new and good block on my first foray....
Posted: Tue Apr 07, 2020 11:11 pm
by Les Schubert
I sent you a email
Posted: Tue Apr 07, 2020 11:26 pm
by Tbz4u
DAN how do the swagelok compare to the a n. Fittings
Posted: Wed Apr 08, 2020 2:24 am
by Dan McEachern
AN fittings use a 37 degree flare as the sealing surface and were developed during WW2 as an Army-Navy (AN) spec for aircraft use. Swagelok tube fittings use a 2 piece ferrule similar to a commercial compression fitting but are manufactured to a much higher quality level, and are generally available in Stainless, brass and steel. They are used a lot in the chemical process industry and anywhere high reliability is needed.
