Simple valve job gone down the tubes
Topic author - Posts: 271
- First Name: Dick
- Last Name: Cruickshank
We started to do a simple valve job, touch up the seats/grind the valves, and found a cracked seat. There used to be a valve grinding fixture that would allow you to counter bore the valve seat with the engine in the car. Does anyone know about this, does anyone have one and will let me borrow it to complete the job. This car is what I call my "beater" and is used in bad weather to save clean-up on my restored T's. It ran fine, no knocks-etc., until this compression started to fail and loss of power and uneven running. I would like not to have to go through a complete dismantle to install a new seat. Any help/advise would be appreciated. Dick C.
- Last Name: Warren
Re: Simple valve job gone down the tubes
That cracked seat will last much longer than one might imagine.
- Last Name: Hatch
- MTFCA Number: 49974
KO Lee made such a tool. If you can find someone besides me that has one. Dan
- First Name: Dick
Dan, any chance I can rent it? You can look up my record to ensure that I am OK.
- First Name: Randall
- Last Name: Strickland
Dick I have a Kwik Way that will do the job,I"m near Mt Airy Nc
two 7 six 7 three three 2 six 2 eight
Randall
Randall
- Last Name: Hatch
Randall is a lot closer. Dan
