On the road again
Posted: Thu Apr 09, 2020 7:05 pm
I got the new valves in our '21 Touring and got the manifolds to stop leaking, after having them off and back on three times. Today I cleaned the plugs and the New-Day timer and it runs good again. I first thought maybe I should have set the valves a little closer but now that I fixed the exhaust leak it sounds ok, probably will be fine once I set the hood back on.
