More "modern" steering column
Posted: Tue Apr 14, 2020 10:04 pm
by Matt_A_1926
Hey guys. So I've started assembling a 27 roadster gowjob/speedster. The T motor is just about squared away. I'm looking at setting up steering soon. Pop has a couple T columns, but also some A columns. I'm playing with the idea of a 30s Ford steering column to give a less sensitive steering for speedster speeds. Can one use an A column? I believe I heard once as well that a later 30s Ford column also fits in nicely.
Re: More "modern" steering column
Posted: Wed Apr 15, 2020 3:46 am
by David Mazza
Model a steering
Posted: Wed Apr 15, 2020 3:47 am
by David Mazza
One more good detail
Posted: Wed Apr 15, 2020 6:23 am
by Chad_Marcheese
You can search for mine I started building, or look on the HAMB forum Model T Gow Job. I too am running an A box...the better '30-31 box. Link:
https://www.jalopyjournal.com/forum/thr ... b.1122709/
Interesting that the above pictures, that the end of the A box has been trimmed and turned down to fit in the clamping bracket, yet for some odd reason they still are running wedges on the clamping bracket. Really no need to do both.
Posted: Wed Apr 15, 2020 10:39 am
David that is a nice clean job on installing. Chad, what do you mean by wedges?
Posted: Wed Apr 15, 2020 11:23 am
by Matt_A_1926
Good looking setup. It looks like I'd have to run the roadster with no sides of the hood though. Hmm, hadn't thought about that.
Posted: Wed Apr 15, 2020 12:21 pm
by TeveS-Nor Cal
A lot of the GO JOBS used early Chevy boxes
Posted: Wed Apr 15, 2020 8:05 pm
by Chad_Marcheese
Edit: Knew I should have kept my mouth shut.....Later Y'all
Posted: Wed Apr 15, 2020 8:25 pm
by Henry K. Lee
That lower strap steel bar is used to dissipate the pressure from the u-bolts equally so not to cause shear.
Hope this Helps,
