1921 Front Spring
James Mike Rogers
Last Name: Rogers
1921 Front Spring
Post by James Mike Rogers » Fri Apr 17, 2020 10:34 am
Can someone give me the eye to eye dimension for a 21 front spring? Mine seems to have sagged some.
MTFCA Number: 4838
MTFCI Number: 115
Re: 1921 Front Spring
Post by DanTreace » Fri Apr 17, 2020 12:22 pm
James
All '09-'25 front 7 leaf assembled spring stacks, main leaf eye to eye are the same. 31 1/2" between the eyes.
What can make the sag is the stack, where the others are fatigued.
Should be about 7' high, un -sprung, with spring assembly resting on the eyes on a flat surface.
RichardG
Last Name: Grzegorowicz
* REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
Post by RichardG » Fri Apr 17, 2020 1:22 pm
JIM, THIS IS IN THE CAR--33 INCH BETWEEN EYE TO EYE, FROM THE CROSS MEMBER TO AXEL IS 4 INCH, GREG.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Apr 17, 2020 2:53 pm
Correct Richard, when front spring is loaded with car weight:
This is a rather old spring on the '23 cutoff, sags some. A well worn one can let the knuckle ride on the axle :?
This is a bit better clearance of a used front spring, but it's being helped with accessory Hassler Pancake shock. (Yes this left perch is twisted to the front for Pancakes...unlike the earlier Beehive that needs the perches switched right to left)
Comparison of perch to perch centers on a standard front axle.
