26-27 Coupe top wood drawings
myersair
First Name: Randy
Last Name: Myers
Post by myersair » Fri Apr 17, 2020 4:17 pm
I'm in the process of restoring a 1926 Coupe and all the top (roof) wood is missing. I'm wondering if anyone has a drawing showing the layout and dimensions. Any help would be appreciated.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Re: 26-27 Coupe top wood drawings
Post by jiminbartow » Fri Apr 17, 2020 5:53 pm
Check out: www.fordwood.com. You can buy a roof kit or, if you want to build it yourself, you can enlarge the schematic for a ‘26 coupe to determine the way it was constructed and use your car to derive the proper measurements for the frame and slats. Jim Patrick
jab35
Last Name: Bartsch
MTFCA Number: 30615
Post by jab35 » Fri Apr 17, 2020 9:52 pm
Don Booth has restored several '26-'27 coupes over the past few years. You will find his posts useful, here is one example giving the info you seek, Good luck, jb
http://www.mtfca.com/discus/messages/59 ... 1460655088
myersair
First Name: Randy
Last Name: Myers
Post by myersair » Mon Apr 20, 2020 8:22 am
Thanks Guys....very useful Info.
fordorgalore
First Name: Don
Last Name: Booth
Post by fordorgalore » Mon Apr 20, 2020 8:53 pm
I have some pictures and also one of the original top wood.
1926 model t coupe don booth (Small).jpg (42.42 KiB) Viewed 1139 times
fordorgalore
First Name: Don
Last Name: Booth
Post by fordorgalore » Mon Apr 20, 2020 8:54 pm
This may help....
myersair
First Name: Randy
Last Name: Myers
Post by myersair » Tue Apr 21, 2020 8:32 am
Don,
This is perfect....exactly what I was looking for. This will make it so much easier and will take all the guess work out of it. I can't wait for the weekend so I can get in the shop and start working on this!
Thanks to everyone for all the help with this.
fordorgalore
First Name: Don
Last Name: Booth
Post by fordorgalore » Tue Apr 21, 2020 11:09 am
I hope it helps …. If I could just add one thing? The coupes I worked on almost all had to have the top pulled forward. The weight of the doors takes a toll and top helps hold the body shape. So I learned to check the door fitment before bolting the top wood down. It doesn't take much for the doors to sag.
myersair
First Name: Randy
Last Name: Myers
Post by myersair » Tue Apr 21, 2020 12:12 pm
Thanks Don,
All good points, I'll defiantly do that before I do the finial drill and install.
Thanks again for all your help.
