26-27 Coupe top wood drawings
Topic author - Posts: 25
- First Name: Randy
- Last Name: Myers
I'm in the process of restoring a 1926 Coupe and all the top (roof) wood is missing. I'm wondering if anyone has a drawing showing the layout and dimensions. Any help would be appreciated.
- Last Name: Patrick
- MTFCA Number: 50126
Re: 26-27 Coupe top wood drawings
Check out: www.fordwood.com. You can buy a roof kit or, if you want to build it yourself, you can enlarge the schematic for a ‘26 coupe to determine the way it was constructed and use your car to derive the proper measurements for the frame and slats. Jim Patrick
- Last Name: Bartsch
- MTFCA Number: 30615
Don Booth has restored several '26-'27 coupes over the past few years. You will find his posts useful, here is one example giving the info you seek, Good luck, jb
http://www.mtfca.com/discus/messages/59 ... 1460655088
- First Name: Randy
- Last Name: Myers
Thanks Guys....very useful Info.
- First Name: Don
- Last Name: Booth
I have some pictures and also one of the original top wood.
- First Name: Don
- Last Name: Booth
- First Name: Randy
- Last Name: Myers
Don,
This is perfect....exactly what I was looking for. This will make it so much easier and will take all the guess work out of it. I can't wait for the weekend so I can get in the shop and start working on this!
Thanks to everyone for all the help with this.
- First Name: Don
- Last Name: Booth
I hope it helps …. If I could just add one thing? The coupes I worked on almost all had to have the top pulled forward. The weight of the doors takes a toll and top helps hold the body shape. So I learned to check the door fitment before bolting the top wood down. It doesn't take much for the doors to sag.
- First Name: Randy
- Last Name: Myers
Thanks Don,
All good points, I'll defiantly do that before I do the finial drill and install.
Thanks again for all your help.
