Any idea what this is?
Posted: Tue Apr 21, 2020 9:02 pm
by Newtexaz
This tool is marked “Truth”. It came with a Truth “model T front bearing race press” I purchased. It looks like it’s for a bearing race because of the taper but the bearing race would be close to 3” in diameter. The 2 pieces on the one end are spring loaded and can both be pushed into the diameter of the shaft.
Re: Any idea what this is?
Posted: Tue Apr 21, 2020 9:22 pm
by Jim, Sr.
Your tool was made by Truth Tool Company in Mankato, Minnesota. I have a 1934 catalog, but it does not show your tool.
Posted: Tue Apr 21, 2020 9:33 pm
by Scott_Conger
It appears to be for removing drive shaft bushing.
If it is for sale, please contact me.
thank you
Posted: Tue Apr 21, 2020 9:39 pm
by Newtexaz
Ahh....that makes sense. I couldn’t picture in m mind what this would be for. Thank you, I think you are right!
Posted: Tue Apr 21, 2020 9:59 pm
by RajoRacer
Appears to be just that - close resemblance to a Stevens d.s. bushing remover.
Posted: Wed Apr 22, 2020 2:36 am
by A Whiteman
This tool looks like it is for installing front wheel taper bearing cones into hubs. Dimensions would help in the analysis.
The race is fitted onto the tapered bush, the part with the hinge goes through the hub and expands to hold the inner side of the hub, then the race is pushed in by tightening the nut?
Other uses may well be found.
It sure looks like a 'shade tree' race press I have.
Posted: Thu Apr 23, 2020 11:04 am
by Newtexaz
I picked both of these at the same time. I know the one is for pressing the wheel bearing races in place into the front hubs. I think those who said the first tool is for drive shaft bushing removal are on to something. The cone fits into the U-joint ball real well. Thank everyone
Posted: Thu Apr 23, 2020 11:30 am
by RajoRacer
That bearing cone press is an actual Ford "Z" tool - quite rare and quite useful. That's only the 3rd one I've seen !
Posted: Thu Apr 23, 2020 4:49 pm
by Newtexaz
Really.... thanks. Good to know. Will certainly take care of it.
