27 fordor spare tire carrier question
Posted: Thu Apr 23, 2020 8:35 am
by bnchief
On my 27 fordor the spare tire carrier wheel mounting plate is bent in slightly at the bottom I am thinking it should be flat.
Re: 27 fordor spare tire carrier question
Posted: Thu Apr 23, 2020 9:24 am
On that gooseneck rim carrier, the triangular plate should be flat.
But the plate is welded to the tube at a slight angle so the mounted tire on the rim won't hit the body.
Posted: Thu Apr 23, 2020 6:07 pm
by NU2theT
Steven here are some pictures of my 26 fordor rear carrier with and with out the spare, hope it helps. If you need any more pictures I can post them for you.
Posted: Fri Apr 24, 2020 1:36 pm
by bnchief
Thank you both i should have mentioned it is a wire wheel spare tire carrier, and that answers my question.
Posted: Sat Apr 25, 2020 11:49 am
by John Codman
My '27 touring car spare tire carrier appears identical to the Fordor carriers in the various photos, and mine came with wood wheels.
Posted: Sat Apr 25, 2020 12:51 pm
Most likely scenario was that the carrier originally sported the split rim "Y" and was backed into something - with the leverage of the attached "Y", I would assume it would/could have bent the flat plate.
Posted: Sat Apr 25, 2020 1:55 pm
by bnchief
Sounds exactly right.
