Source for 6 Volt LED Bulbs (not Headlight)
Posted: Thu Apr 23, 2020 11:51 am
by DontKnowMuch
I am looking for suggestions for direct replacement 6 volt LED bulbs for Tail lights and period correct turn signals. These are single contact and double contact parallel pin bulbs. I have found numerous 12 volt versions in both white and red for less than $2 each but still looking for 6 volt versions.
Any suggestions?
Re: Source for 6 Volt LED Bulbs (not Headlight)
Posted: Thu Apr 23, 2020 12:13 pm
Try this place;
https://www.ledlight.com/6-volt-negativ ... ights.aspx
Look for ones that are rated in the 6 volts range. Many on this site are not polarity sensitive. I would stay away from any that are rated, say 0-36 volts, they don't seem to be bright at the lower voltages. These would be best powered by battery not magneto (AC verse DC).
To add; other thing is to watch the base size, some fit better in the standard socket some do not. Color; The web site I posted suggest using the same color bulb as your lens, red lens red bulb etc.
Posted: Thu Apr 23, 2020 12:16 pm
by Jim_PTC_GA
This is something I will be hunting for when I get to the rewiring of my delivery/hack. Just a quick search on Amazon.com turned up quite a few results.
https://www.amazon.com/s?k=6+volt+led+b ... nb_sb_noss
I've never used any of these but it gives me hope that they are listed.
Jim
