Coil hint
Dave S
First Name: David
Last Name: Simmering
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1925 Coupe, 1926 Roadster Pickup
MTFCA Number: 11531
MTFCI Number: 10138
Coil hint
Post by Dave S » Fri Apr 24, 2020 1:25 pm
After rebuilding a coil I throw the used points in a drawer. I seem to have trouble throwing away something that old. Now, when the upper bridge needs to be elevated for proper alignment I snip the brass holes from a used upper bridge. They make an excellent shim. FWIW
Last Name: Gregush
MTFCA Number: 52564
Re: Coil hint
Post by Mark Gregush » Sat Apr 25, 2020 11:11 am
Re using for shims, been doing that for a while. ;) But like you, I have a bunch of them that I too can't seem to toss out.
1920 Dodge touring
Re: Coil hint
Post by Allan » Mon Apr 27, 2020 3:38 am
I use the same piece the same way, and also a second way. The keys to my Ts have one bearing my mobile phone number attached to the keyring. I like to think a finder might al least want to know what he has found!
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Coil hint
Post by Adam » Mon Apr 27, 2020 10:12 am
Many coil rebuilders use 5mm metric washers. They just barely fit over the stud and are the same outside diameter as the standoffs.
Moxie26
Last Name: Jablonski
MTFCA Number: 407
Re: Coil hint
Post by Moxie26 » Mon Apr 27, 2020 12:34 pm
Adam, I've done the same thing buying those 5 mm washers... But why purchase something when you have something that you could modify and fit s just as well..... Not wanting to spend money but just to reuse something on hand to help with the physical correlation of the top hardware on the coil. Always needed is a pair of side cutters to create that new spacer from the old worn bridge point hardware.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Coil hint
Post by Adam » Mon Apr 27, 2020 9:06 pm
Well... Because they are maybe $0.03 each and a perfect fit. But maybe I’m just a stickler for details... I also had these made up to add a little “bling” to the coils. (But seriously, there is nothing wrong with making the “homemade” shims from old points. It works too.)
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Re: Coil hint
Post by KWTownsend » Mon Apr 27, 2020 9:43 pm
Very nice, Adam. I've been temped to paint the old bridge risers with copper colored spray paint...
I've been using 5mm washer for years.
