26 Transmission Drum Wiggle
MN_Ford_Fan
First Name: Ryan
Last Name: Uecker
Post by MN_Ford_Fan » Fri Apr 24, 2020 9:16 pm
After finding a piece of lug shoe stuck to my magnets, I broke down the transmission to get a look. Sure enough, 1 shoe gone and all but 1 damaged in some fashion. I noticed while spinning the hubs to get a look at the gears, with the assembly sitting in the position shown in the pic, the reverse drum would brush the gears creating a soft scraping sound. So I grabbed the whole drum assembly and gave it a wiggle and it has some slop. If I deflect it in one direction, the gear set below also deflects out of its plane. I can do this around the drums to each gear set. Is it normal to have this type of "slop" in this orientation and at this level of disassembly? Or do I need to keep going?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: 26 Transmission Drum Wiggle
Post by Dan McEachern » Fri Apr 24, 2020 10:44 pm
It appears the transmission / flywheel is not bolted to a crankshaft. If so, there is nothing holding the trans main shaft in alignment and positioned properly with the flywheel, so yes it normal.
Jem
First Name: Jem
Last Name: Bowkett
Post by Jem » Sat Apr 25, 2020 2:28 am
Mike Bender recommends you work on the trans with it bolted to the engine on an engine stand. Makes it easier to check for runout with a dial gauge etc.
He makes the good point that the factory had separate shops for engine and trans assembly, we restorers are only doing one at a time. Instead of heaving a complete trans on and off to set the gap, you do it with flywheel alone, bolt that up and then assemble the trans in situ. Check out his trans rebuild videos on YouTube.
Andy Loso
First Name: Andy
Last Name: Loso
MTFCA Number: 346
MTFCI Number: 119
Post by Andy Loso » Sat Apr 25, 2020 10:12 am
Normal, but as long as you are this far, I'd tear it down to inspect everything.
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Sun Apr 26, 2020 2:35 am
I agree completely. While you have the transmission out, I would fully disassemble it and check it's condition. Rarely will you find a transmission that does not have something wrong with it.
Stephen
rgould1910
Last Name: Gould
Post by rgould1910 » Sun Apr 26, 2020 9:54 am
Install the driving plate and see if the problem disappears.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sun Apr 26, 2020 11:16 am
Richard- bolting on the driven plate will do nothing to stop the man shaft flange from flopping around in the flywheel.
Post by Mark Gregush » Sun Apr 26, 2020 3:29 pm
I have a cut down crankshaft I use for this.
1921 Huckster
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Apr 26, 2020 3:59 pm
I had a flywheel mandrel machined for doing transmission assembly & setting the magnets.
