Jack and rim spreader
Posted: Sat Apr 25, 2020 7:54 pm
by dhosh
I just picked up this huge mechanical jack from a fellow that saved it from a metal recycle bin... I really wanted one of the small lift ones, but this one is actually long enough to reach the rear axle on my RPU , with a longer than normal bed.
Worked on my Subie too... Swapped out my snow tires!
The fellow threw in a rim spreader, as well, as he didn't have a use for it. Anyone sonlmewhat close to me (Petoskey, Mi) that could use it?
Re: Jack and rim spreader
Posted: Sat Apr 25, 2020 7:56 pm
by dhosh
Anyone have an idea as to the age of the jack? The only info on it that I have found is Pat(ent) 10 5 on the cross member between the two small pivot wheels.
Posted: Sat Apr 25, 2020 8:59 pm
by Dallas Landers
Good score Dennis!
Posted: Sat Apr 25, 2020 9:09 pm
by dhosh
Thanks! That's unusual for me! LOL!
Can you tell if the crank thing is a bead breaker ... Or a rim spreader? I've never seen it used either.
Posted: Sat Apr 25, 2020 9:29 pm
by Dallas Landers
Rim spreader. The hook part grabs the rim and pulls it in. It also pushes it back into place once tire is mounted. For split rims. I used mine yesterday.
Posted: Sat Apr 25, 2020 9:34 pm
by dhosh
Very good. That's what I understood.... One is in classifieds..
Looks like it's labeled as a 'bead breaker'... Knuckle buster, maybe! Lol!
Posted: Sat Apr 25, 2020 10:04 pm
by Dallas Landers
They are your best friend on split rims. They can bend them if too much force is used. The 27 Im working on is that way. The spare tire will not fit on the wheel because the ends are bent in too much. Will need straightened.
Posted: Sun Apr 26, 2020 12:15 am
by D Stroud
Nice score Dennis!!!! That jack is awesome! You for sure won't need to worry about it leaking down! Dave
