Conversation starter...Oh the possibilities
Topic author - Posts: 2345
- Last Name: Hanlon
- MTFCA Number: 50191
My friend Medina Bill made this.
Just a watzit, but I suggested putting something in it....firewater maybe ?
I like it, what would you put inside ?
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Conversation starter...Oh the possibilities
MMO ! Purdy and usefull.
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926
- MTFCA Number: 29784
- MTFCI Number: 22970
How hot does it get?
This would start limiting the possibilities.
Some blood red water would make folks do a double take.
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
I agree with Dallas. Marvel Mystery Oil is always good for a conversation .... Add a small Marvel Mystery Oil decal to the glass for more fun things to talk about.
- First Name: Dennis
- Last Name: Seth
- First Name: Neil
- Last Name: Martin
- * REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
perry kete,
Tropical I hope...N.
- First Name: George P
- Last Name: Clipner
- MTFCI Number: 18665
Era correct coffee percolator.
Lava Lamp Fluid - mostly water, oil ad some food coloring. The heat from the radiator may cause it to react.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Bunch of Hippies!!!!!
- First Name: Henry
- Last Name: Petrino
I agree with the fish idea. It would work like a manifold cooker, only with steam. Fish dinner when you arrive at your destination.
- MTFCA Number: 52564
I was think about the fish but would go with their little white bleached skeletons floating around inside. Maybe those balls they use in water thermometers.
https://www.zmescience.com/other/featur ... ter-03213/
1920 Dodge touring
1920 Dodge touring
- Last Name: Patrick
- MTFCA Number: 50126
Nice! Looks like an old fashioned glass gasoline pump reservoir. I would put in some water colored with green and red food dye to resemble the reddish brown color of gasoline and put a “Texaco” decal on it. Bourbon or tea with a little red food dye would work as well. Jim Patrick
Couple of these floating around
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
- Board Member Since: 2010
I was thinkng coffee grinds but that would cause too many questions to be asked. MMO sounds about right. Finally something it's good for.
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
- MTFCA Number: 31822
I like the idea of the tiny rubber duck on water but I would fill it with mannequin fingers to symbolize all the smashed fingers I've had restoring the T.
Just give me time to Rust and I'll be good as new. Wabi-Sabi
- Last Name: Hanlon
LMAO !!
How bout a little oil and some popcorn ?
If the T gets too hot, the popcorn pops and you pull over and have a snack while she cools off.
- First Name: Ralph
- Last Name: Sullender
- * REQUIRED* Type and Year of Model Ts owned: 21 tt
- MTFCA Number: 50327
A bit of HOT salsa to go on the burritos warming in your manifold cooker !
Around and around we go and where we stop we check the gas oil water and tires.
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Probably a little roll of solder because that much weight will break the radiator neck loose.
I assume you know it's a drip oiler.
Looks cool, I would put something that would fizz and make a decal that said, "Dr Fitt's Stay Cool for Fords" or something like that.
- Last Name: Grzegorowicz
THAT'S A GREAT IDEA, THE DUCK I THINK WOULD BE PERFECT, A FEW YEARS BACK I RESTORED A M-D- INTERNATIONAL TRACTOR, I PUT A MODEL OF A JOHN DEERE IN THE GLASS AIR FILTER, IT WAS MOST A YEAR BEFORE IT WAS FOUND, NOW I SEE THEM A LOT AT THE SHOWS. GOTTA HAVE SOME FUN ONCE IN A WHILE.
That would be a good way to say that M-D- INTERNATIONAL left John Deer behind in the dust.
1920 Dodge touring
1920 Dodge touring
Put little blue ford ovals in it and say its giving birth to baby fords.
- First Name: Garland E
- Last Name: Pobletts
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Add an upper chamber and use it to brew coffee when you overheat. A nice cup to sip while you wait for it to cool down. No antifreeze.
- Last Name: Hanlon
“Something fizzy...”
How about some Bromo Seltzer ?
Settle that burping radiator !!
Faux Ice cubes floating in mineral oil. Don't want anything to freeze
- Attachments
- A68CDD8E-8881-41AF-9925-3A73E742BF07.jpeg (35.97 KiB) Viewed 6433 times
