T Snowmobile?
GJScholz
First Name: Gregory
Last Name: Scholz
MTFCA Number: 30705
T Snowmobile?
Post by GJScholz » Mon Jan 07, 2019 4:52 pm
I Always thought a T snowmobile had dual rear wheels and a track.
But I see on the Snowmobile meet post, one of these:
Was this a common thing to do?
It would seem to me that by installing skis, and adding chains or as seen here those buckle cinches, a guy could have a lotta fun on a frozen lake.
Is it really just the matter of the skis, and chains?
Greg Scholz
4th Generation Caretaker
1914 Ford Touring
Survivor Class
http://personal.gregscholz.com/
Esko MN
KD0UYN ‘73
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Re: T Snowmobile?
Post by Humblej » Mon Jan 07, 2019 5:44 pm
Technically that is not a snowmobile. With regards to a model T, Snowmobile and Snowbird are brand names for accessory tracks with double rear axles and wheels...The tracks define the "snowmobile", not the skis. The problem with snow or mud is ground pressure, higher ground pressure will cause a wheel to sink and get stuck, lower ground pressure will allow it to "float". Tracks and dual axles decrease the ground pressure considerably, and the metal track pads increase traction, resulting in superior soft ground mobility. Skis and tire chains would be fun on ice or packed snow, but ineffective in deep snow or powderd snow.
GJScholz
First Name: Gregory
Last Name: Scholz
MTFCA Number: 30705
Re: T Snowmobile?
Post by GJScholz » Mon Jan 07, 2019 10:01 pm
Thank.you.
The more I learn, the more I don't know.
Greg Scholz
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Re: T Snowmobile?
Post by Duey_C » Mon Jan 07, 2019 10:06 pm
Although not technically a Snowmobile, that's a really OLD model T Snowmobile!
Really neat pic Greg!
Hahaha! I feel the same about learning!
GJScholz
First Name: Gregory
Last Name: Scholz
MTFCA Number: 30705
Re: T Snowmobile?
Post by GJScholz » Tue Jan 08, 2019 10:59 am
Thanks Duey!
Now I don't feel so alone.
I stole that pic from the Snowmobile Event post.....
Greg
Greg Scholz
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
