Lifter question
Topic author - Posts: 164
- First Name: Mike
- Last Name: Sleep
- * REQUIRED* Type and Year of Model Ts owned: I have 26 & 24 coupe, 25 pickup, and 26 Fordson.
- MTFCA Number: 31639
- MTFCI Number: 31639
Lifter question
I am helping a friend with a valve job. When we pull up the valves there is a “cap” over the lifter. It is small and can be removed. My cars all have adjustable lifters and I had not seen this before. Was this standard for the non adjustable lifters? Thanks Mike.
- Last Name: van Ekeren
Re: Lifter question
No, not standard for the T engine, rotator caps would have been used in a rebuild some time later in it's life.
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Re: Lifter question
Mike:
also , there are shims that were used over the ends of the tappets to take up excess wear or to correct the clearance when too much material was removed from valve stem or tappet ( lifter) during a valve job … these stamped cups were usually in the .015 to .030 thickness … don't see these very often … always an optimist ..gene french
- First Name: Mike
- Last Name: Sleep
Re: Lifter question
Did they fit over a standard lifter, or is it a special lifter? I would assume the valve would have been shortened a little to get clearance? What was their purpose? Thanks Mike
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Lifter question
It’s an accessory part that was put over the end of the tappet because the end is worn too deep. People used these shims when they did a valve job instead of replacing the tappets. If they aren’t worn thin, you can leave them in there. If you have the cam out, you should replace the tappets.
- First Name: Thierry
- Last Name: Michot
Re: Lifter question
The post is a bit old but,
Would you know if you can still buy those caps ? I would like to adjust valve lashes on the cheap ! I plan to rebuild that motor later on.
Thanks in advance.
Thanks in advance.
- First Name: Randall
- Last Name: Strickland
Re: Lifter question
Lash caps are used a lot in racing engines
https://www.summitracing.com/search/pro ... =part-type
- First Name: DAN
- Last Name: MCEACHERN
Re: Lifter question
Not sure you are going to find a lash cap made to go on a 7/16 diameter valve stem. But depending on how worn the end of your lifter is, you could always use a lash cap in the conventional manner and put it on the valve stem.
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
Re: Lifter question
At 8 bucks a piece, new valves are not a deal breaker. The new valves are plenty long, If your lifter is too worn to adjust with a new valve, you need a lifter, again not very expensive.
Andy
Andy
- Last Name: Michot
Re: Lifter question
Thank you all for the replies .
